Warm up temps..
Old Nov 14, 2016 | 12:49 PM
snotrod's Avatar
snotrod
Warm up temps..
Just wondering what is normal.. I've only ever driven my 6.0.
When I do a true cold start, my coolant temp rises faster than my oil temp. usually about 10* higher. then around about 140* the oil catches up, then maintains about a 5-10* delta above coolant. (10 month old oil cooler, EGR delete). Oil stays in the 180* range, coolant in the 170* range. Does this sound right? Gets hotter if I'm hauling or towing.
Also, since my recent oil change (mobil 1 full synthetic to rotella full synthetic), I've noticed the oil is much closer to the coolant temp than it used to be. Normal? less gunk in the oil to keep it from heating up as much?
Sorry, one last question..
When my truck is cold, it has no power until the coolant is about 140* (or the bottom line on the gauge) , and then its like a switch is turned and it drives like normal. I guess it could be a temperature related to the oil temp too, I've just noticed it's right around 140* coolant. My question is.. I've been hearing it could be the ICP or stiction. any guesses?
as always, thanks for the help
Old Nov 14, 2016 | 01:06 PM
christaylor's Avatar
christaylor
I was having similar temp and changed out my thermostat and now have 190+ coolant temps. My guess is your thermostat is stuck open.
Old Nov 14, 2016 | 01:20 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Like he ^^^ said, you need a t-stat first off.
Then what's your engine and FICM voltage before and after the truck wakes up.
Old Nov 14, 2016 | 01:35 PM
snotrod's Avatar
snotrod
Do the t-stats get stuck full open, or just partially open?
Old Nov 14, 2016 | 01:42 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Yes! I would install the Mishimoto 200° stat. I did and it bettered the oil/coolant spread another 5°. Ford says to have a 190 stat. Theirs will not keep temps at 190 for long. They always seem to fail open and truck runs crappy after that.
Old Nov 14, 2016 | 01:43 PM
WatsonR's Avatar
WatsonR
When failing, then fail to the cold side... you need a new one. It should be closer to 192*. Also, you switched from Mobil 1 to Rotella T6? From good to worse.... switch to Delo LE400 5w-40, much better oil and even cheaper than T6!
Yep... the Mishimoto 200*... way better than the Ford 192*
Old Nov 14, 2016 | 02:38 PM
christaylor
Mine was not "stuck" The spring was just weak and letting coolant through too early. Long drives 170* hauling maybe 200* Not too bad to replace. I should have done the upgrade but bought the ford replacement. Next time will go with the 200*
Old Nov 14, 2016 | 03:50 PM
AGE mechanic's Avatar
AGE mechanic
You definitely need a new T-stat.
Old Nov 14, 2016 | 09:18 PM
TxMav's Avatar
TxMav
^^^^^​​​​​​​Listen to this guy.^^^^
DeeJayWoody
Jul 19, 2014 08:12 PM
Traildust
May 23, 2013 05:39 PM
carmk
Apr 18, 2012 08:27 AM
ConvertedFord
Jan 26, 2010 09:05 AM
Blaster7Romeo
Jun 6, 2008 09:44 PM
