Just did a light rebuild on my new to me carb. Just replacing the needle and seats and gaskets accordingly, it was stalling at stops unless I kept blipping the throttle.
After reinstalling I was adjusting the floats and I don't know if I messed it up, or if it already was, but the rear needle wouldn't tighten again. It seems that the threads in the bowl are stripped.
Are there any quick fixes for this, or am I limited to getting a new/replacement rear bowl?
Why do people hide their locations, the advice I give is different cause you're in commiefornia, why do you make me look?
Yeah I stripped mine to, no other solution then to replace the bowl. Given that those bowls are unique that can be a tough thing to do, and given that your in CA you likely can't just put on a normal 4160 bowl.
Not sure why it says I'm on California, I'm in Ontario Canada.
I don't think that the 4160 bowls are the same shape anyways.
Originally Posted by raystankewitz
It might help us if you gave us the Holley LIST number off of the choke horn. Should be in front on the right side.
List number is 50264-1
Ford Number is E5TE-9510-ZB
I can't tell how big that hole is, but you might try to repair the threads. You can make a positive seal with a keen-sert, and thread sealant around the insert. Just use a sealant that is rated for gas. If the insert is larger that 50% of the wall thickness you have left I would replace the bowl though.
I saw "CA" and assumed comiefornia. instead of commianadada.
A 4180 is just an emissions version of 4160, as far as the bowl is related the only difference is the stupid extra vent on the top. Toss on a 4160 bowl and skip the vent.
Or buy a better carb and sell that one, it's been a while but I think those still have a fair amount of value to people who want/need to keep their rig stock. On RockAuto they have a $115 core charge, that says something.
I'm looking to keep the truck stock right now. It's a one owner rig and was well maintained, I'm trying to see how long it will last with OEM(ish) parts. I also don't have the money to get a new unit.
Thanks for the info on the 4160, I was told that they were different. I was given a kit for one and the gaskets didn't line up, but the kit could've been wrong.
Originally Posted by ArdWrknTrk
Holley float adjusters are 3/8-24. (an odd pitch to find a thread repair insert)
4160 bowls have the same shape and depth, just no vent elbow.
primary and secondary are different, be sure to get the right one.
I've never worked on a carburetor before this one so I don't know much. I'll do some more research to make sure I order the right one! It is the 'rear' float, the one that would be closest to the firewall. I would imagine this is the secondary?
Installed length is a half inch.
How's that going to work in the roof of a float bowl?
besides the insert you need the tap and the insert tool.
How much is the kit?
Say, $15 for the tool and $12 for a tap you're at $31 before shipping
Yes some gaskets differ from a "normal" 4160, but not the bowl gaskets.
My best piece of advice would be to make some phone calls to local carb shops, if there are still any around in your area. Tell them what you have and offer to trade. That you'll give them your 4180 plus IDK up to $100 for a 1850 in good condition. The 1850 is the "standard" Holley version of your stock carb, is a VERY popular carb, and has many advantages to you. Mostly two things, it doesn't have those idiotic bowl vents, and it is much more adjustable. If it has the gold finish it will look stock to anyone not in the know.
EDIT, on a deal like that make sure you keep/swap a few parts, keep your electric choke, and make sure you at least notate or keep your current, jets, metering plate, and power valve.
There's only one carburetor shop in my area, I'm going to call them now. I also emailed a guy about a used 1850 with manual choke. But it seems like I can just move everything from one carb to the other?
Thanks for the information though. I appreciate it.
4180's use Holley's 3-1346 rebuild kit.
The jetting and specs are available from the tech library on their site.
Across the top of pages 15-16 of the carbs by list number pdf.
That was the kit that I ordered the second time and the one I used for the rebuild. The first kit I ordered was a 37-119 kit.
The 4160 secondary bowl on eBay is only up to $1.45 right now, with five hours left to go....
$7.50? shipping sounds like a USPS flat rate box.
Idk about duties or tariffs going to Canada.
Maybe you could look on eBay.CA? for one that wouldn't involve customs
