Changed the turn signal switch on my 86 F150 and noticed a terminal for the key in buzzer. After a little research I found that the buzzer should be behind the glove box and also serves as a headlight on warning. The base models didn't come with the buzzer but the harness is there. Found a guy on eBay selling OEM buzzers for $21.96. Got one, plugged it in and I now have key and headlight warning. He still has 10 available. Search part # E43B-10B924-AB
Clueless ebay seller listed the ID number marked on the part as the part number.
E4TZ-19B924-A .. Headlamp & Seat Belt Warning Indicator Switch / Marked with ID number: E43B-10B924-AA or AB / Motorcraft SW-1822) / Obsolete ~ 13 available NOS
1984/88 Ranger & Bronco II / 1984/96 F150/350, Bronco & Econoline / 1986/88 Aerostar / 1989 Ranger Super Cab.
I have an 82 F100 I get a buzzer with key on but it doesn't warn about the headlights being on and mine is behind /above glove box maybe that's a year change feacher
1980/83 uses a different switch (D6AZ-10B924-A and it's only for the seat belt)...than 1984/96.
1. the engine is OFF,
2. the lights (or markers) are on,
and
3. the door MUST be open.
opening the door with lights on triggers the buzzer to buzz.....
and
More details about the wiring changes, please. I'd like to modify my buzzer like that, too.
