TMI Pistons
Old Nov 12, 2016 | 12:45 PM
Kyle Wood's Avatar
Kyle Wood
i think i found pistons thatll work if i bush the ends of the 400 rods. Kieth black kb177. found a chart that says itll yield a 9.5:1 ratio. i just dont know about valve clearance and im not sure how to figure that out. they are flat tops. and i just have a mild cam (.494 cam lift with 1.73 which is stock rocker ratio)
Old Nov 12, 2016 | 01:48 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by Kyle Wood
i think i found pistons that'll work if i bush the ends of the 400 rods. Kieth black kb177. found a chart that says it'll yield a 9.5:1 ratio. i just don't know about valve clearance and im not sure how to figure that out. they are flat tops. and i just have a mild cam (.494 cam lift with 1.73 which is stock rocker ratio)
Contact KB and ask.... you'll need to know the compressed head gasket thickness because they will ask or at least provide a recommendation. Also ask what the minimum clearance from the valves.
Then verify by installing the head, head gasket, etc. and some modeling clay (even Playdough will work!). Rotate the crank 360 degrees and allow the valves to dent the clay atop the piston. Of course if the rotation suddenly stops then ya know there is zero clearance.
If not, complete the 360-degree rotation and disassemble. Peel off the clay and cut (bisect) where the valves have compressed the clay. Measure. The thicknesses will need to be enough for expansion of the valves and the piston.
Old Nov 12, 2016 | 05:01 PM
gatorfor88's Avatar
gatorfor88
And if all else fails just bolt dat biotch together and spin her up to bout 8599 rpm. If she dont blow she will go.
Kyle Wood
Nov 10, 2016 01:30 PM
just-n-time
Jan 28, 2009 03:28 PM
BlueOvalBoy23
Nov 17, 2007 06:42 AM
Dixie Pirate
23
Aug 29, 2003 09:24 AM
Ford_Six
Jan 15, 2003 07:26 PM
