Cigar lighter
Old May 24, 2011 | 03:52 PM
j7angus's Avatar
j7angus
Cigar lighter
I am hooking up the cigar lighter on my 79 I am running a 14 gauge wire directly from the battery to the lighter I was thinking I should put an in-line fuse close to the battery for some extra protection anyone know the amperage of fuse I should use on the in-line fuse holder?
Old May 24, 2011 | 04:29 PM
lance65's Avatar
lance65
on my '77 the power for the lighter comes from a green wire on the glove box side. But YES I would use a fuse in-line.
Old May 24, 2011 | 04:39 PM
j7angus's Avatar
j7angus
Any idea on the amperage of the fuse that I should use? I am thinking 20 amp.
Old May 24, 2011 | 05:37 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Now were talking cigars. All you need is a Brandy dispenser or Beer tap.
Yes a 14 awg would be fine with 20 amp fuse.
I would run a ground back to the battery since its has to pull a few amps to heat correctly. You don't need any hot spot on that cigar.
