Post #5 tells you what you need to know about the GPCM. Pin #s, how it works, when it works and the whole 9 yards. Check that attachment he sent you again. It applies to your 2002 as well.
Yeah I have it that's how I found I needed to replace my pcm, but it says nothing about the constant power that I originally made this post for, but some new things came up in the process lol
AH, ok. Now we are getting somewhere. It is certainly possible the Edge corrupted something...or the sequence of events you followed did. Does the Edge use the serial data port under the dash to remove the one that was on it and load its program?
Yeah it uses the OBD port. Sorry I thought I had mentioned that before but I guess I didn't. I am thinking the edge corrupted something during the initial boot up sequence but am not to sure until I can contact them tomorrow and see what they plan to do about it lol I don't wanna pay another $130 dollars to have it programmed again lol and worse if the edge f**** up again. But it sucks paying $800 for this tuner and i can't even use it lol
