400 piston options?
Old Nov 10, 2016 | 08:05 PM
Kyle Wood's Avatar
Kyle Wood
400 piston options?
So i know these are options,
1. Buy Tim Meyer's pistons (very good option but costly at $425)
2. Buy 351C pistons and bore the wrist pin out to accept the 400 wristpin (if there is enough material)
3. Buy 351C pistons and bush the 400's small end of the connecting rod to accept 351C wristpins.
I am on a budget so i would like to stay away from Tim's pistons unless i uncover some money i didnt know i had (I wish), so has anyone done 2 or 3? how were the results? how much did it cost to have machine work done ( bore the wrist pin bigger or bush the connecting rods). How is the reliability issues which increasing the wrist pin diameter or bushing the rods and decreasing the wristpin diameter?
Im looking for a ballpark idea. If the options come close to Tim's price i will just pull the trigger one those since its a direct fit.
If anyone who has pulled off 2 or 3 could chime in and give me the details it would be very appreciative!
Old Nov 10, 2016 | 08:50 PM
hurst1979olds's Avatar
hurst1979olds
Ultimately, what is your goal with this build? You can always go with a cast 400 piston if it's like a stock rebuild. You can get those for under 200. Sealed powered makes good pistons.
Old Nov 10, 2016 | 09:29 PM
Kyle Wood's Avatar
Kyle Wood
My goal is for performance ( i should have included that). i want the CR around 9.3:1 maybe alittle higher or if it has to be alittle lower. stock CR for a 78 is i believe 8:1 or maybe even alittle lower. High CR = more power/ better gas (although i dont care about gas mileage)
Old Nov 10, 2016 | 10:45 PM
PapaBearYuma's Avatar
PapaBearYuma
One not concerned about the mileage need not be concerned about spending the extra bucks for the TM pistons. Is not a fill-up over $75?
Old Nov 11, 2016 | 02:27 AM
matthewq4b's Avatar
matthewq4b
The best option is to bush the rod end. But by the time you pay to bush the rod end then re-balance you will have spent more than the $190 difference in cost between 351C pistons and the TM pistons.
Old Nov 11, 2016 | 08:15 AM
POPAJON's Avatar
POPAJON
I did the 351C flat top pistons and bushed the small end with 292 bushings. I found the cost cheaper. The cost of shipping, duty and broker fees was ludicrous to say the least'
Old Nov 11, 2016 | 09:36 AM
tbear853's Avatar
tbear853
I had always heard either use Tim's pistons or bush the rod ends for 351C pins if looking for higher CR in a 400, never heard anyone boring the wrist pin hole in the pistons out. Also know that many had used Aussie 302C heads but I expect those are about gone.
You mean like these?
Piston Pin Bushing Set of 8 Ford 292 312 V8 1961-64 223-3515 (8) Clevite | eBay
292 bushings huh? I'll have to look into this.
I ran up on a set of Zollner Z3436 pistons and used them ..... but I considered that bushed rod end route for my basement motor that just "hangs out" on a stand so far ..... just figured I'd need custom bushings.
Awe ..... but seriously I doubt I'd change them now though, likely I'll end up selling the motor ..... already have a guy who wants it pretty bad, just hate to let go as long as I have the '77.
Old Nov 11, 2016 | 05:28 PM
Kyle Wood's Avatar
Kyle Wood
I dont mind spending money but my budget is low now. By the time this engine is done i will have recovered momey for gas. I cant believe no one else sells a high CR 400 piston.
What cleveland piston would achieve around a 9.5 CR. I tried using the calculators but now entirely sure if im using them right. I i have 76cc heads and felpro 400 head gasket
Old Nov 11, 2016 | 11:37 PM
buckin69bronco's Avatar
buckin69bronco
Don't know if you've been to Tim's web site lately but it now says the pistons come with rings now. I can't see how lower cost 351c pistons with a sub 1.710 compression height and the need to do something to make them fit the rods will work as good or be too far from the cost of TMI pistons.
Kyle Wood
Nov 18, 2016 05:38 AM
choppergeorge2003
Jan 22, 2014 07:04 PM
Snorri_B
Apr 2, 2012 07:23 PM
393STROKER
Sep 1, 2011 01:08 PM
Deadman2891
Jul 4, 2004 11:15 AM
