Any help with where to buy the following or recommendations on the competition or alternative solutions would be greatly appreciated!
Looking to install airbags fairly quick. I'm the keyboard jockey while my dad is the mechanic. I do plan on driving down to his shop to install these things. While I am approaching 40 I am still pretty good at handing him the tools.
Thoughts? There have been a few other things mentioned but the most frequent has been airbags. And I'm thinking you need a separate purchase to make sure you can get air in and out of those suckers, thus the need for the wireless one system.
Look at the load lifter 5000 airbags. I just installed them myself on my truck. They have an internal jounce bumper so you can run the bags at 0 psi. They are also a little less expensive than the ride rites. I didn't get a compressor. I ran my lines thru the license plate and fill with a portable compressor I keep in the fifth wheel.
Does it have the same connection as a tire? When putting air in? That would be perfect actually. It's not like I would be constantly filling it up.....
Yes it does. Just like airing up a tire. I use a 12v compressor to fill up the bags. Doesn't take much to fill them up. In fact, you could use a bicycle pump
I installed the Firestone bags myself in a morning and had never done it before. It was a straightforward install and I ordered the optional "T" where I joined the lines and then ran one line to the rear so the pressure is equalized at the bags. They also provide a heat resistant protector for the line by the exhaust pipe. Very satisfied.
I may have been the one to suggest the Wireless One compressor, not sure. I just bought (starting to install today) AirLift 5000 and Wireless One compressor for my 2000 F-250. I too was going to route the valves to the rear of the truck and fill up when I needed, but I don't have easy access to a compressor and thought it would be a bit cumbersome to find one and fill them each time.
AirLift has a $50 rebate on the compressors right now found here.
I just thought it was worth the peace of mind with having an on-board compressor for adjusting the pressure and having preset settings for with and without our 5th wheel. As Tom suggested, I was going to tote around a bicycle pump to air the bags up, but thought that I spent money on the bags and making everything right, but then was going to go cheap on the pump and use a hand pump each time, that just seemed silly.
I have no opinion on how they work because they are still in a box, but the reviews and thoughts around the net are they are good.
Again as Tom suggested I bought the 5000 series bags so that I could run them at 0 PSI and not worry about it.
You might want to consider separating the lines to the air bags. Here's why: if you have a load that is on one side of the truck, the air bag on that side compresses and pushes all its air to the other side. This magnifies the side to side body roll. No fun if you're towing or hauling a load. Just my .02
I don't do much diverse hauling. So far 100% heavy load has been the 5er but you do make a good point.
I have the Firestones on my truck. Had them installed and have a single fill inlet that sits behind my gas door. Hides the fitting out of sight, and also mostly out of the elements. Not having any issues with a single fill nozzle. I'm not road racing my truck with a 2K weight hanging off the side of one bed rail, so I seriously doubt I'll have any issues with bags moving air from one side to the other.
Or forget about the separate fill lines or the sway if you don't use separate lines or heat shields for the one by the exhaust pipe or on board compressor or separate compressor or bicycle pump or where to put the nozzle or what pressure to have hauling or not hauling.
Timbrens install in about an hour with the appropriate beer break.
JMO.
JMO.
Yea, this is the direction I went. Works perfect for my situation, and I realize all situations are different. I like not having to mess around changing the air pressures.
