55 239 Yblock help
Old Nov 9, 2016 | 01:38 PM
Silver54's Avatar
Silver54
55 239 Yblock help
Hey, we have a 239 yblock from a F350, just wondering if the Y block,another 239 but from a car, would be worth it to pick up for a parts engine. If you could let me know that would be awesome!
Old Nov 9, 2016 | 03:25 PM
charliemccraney's Avatar
charliemccraney
If you plan to keep it as original as possible and it is also a 1955 239, absolutely. 1954 239 are in many cases not interchangeable with other Y-Block parts.
If you want to upgrade, then the money will be better spent on a 272, or 292.
Refer to this site so you can identify what you have and the engine you are considering to buy.
http://www.ford-y-block.com/technical.htm
Old Nov 27, 2016 | 09:16 AM
Silver54's Avatar
Silver54
Thanks Charlie, been away for a bit, but that is exactly what I was looking for
Old Jan 28, 2017 | 09:28 AM
Silver54's Avatar
Silver54
Alright, so we have the Y block cleaned up now, rotating freely with the valves relapped and decent enough compression, mostly 100-110, with one weak cylinder that needs run in again to reseat. Wondering if anyone has down a carb rebuild kit out there. I have found a float to get but I haven't been able to find a gasket kit. Would one of you fellas know where I might find one?
Old Jan 28, 2017 | 10:43 AM
charliemccraney
It's a 3-bolt 2 barrel, so Holley 94 or Stromberg 97. I don't know where to find kits, but given their popularity, they should be pretty easy to find.
Edelbrock also make brand new 3-bolt 2 barrels.
Stromberg still make them.
Those gives you more options.
The compression is pretty bad. If the numbers don't come up after it's been run for a while, get ready for a rebuild, at which point you should seriously consider upgrading to a bigger Y.
Old Jan 28, 2017 | 03:27 PM
Silver54's Avatar
Silver54
Thanks for the info Charlie, I think I may have found a kit that will work, just wasn't 100% sure on which carb it was till now. As for the compression it's not going to be a race truck, just needs to drive a couple of miles back and for a couple times a year is all. But those numbers should come up after the engine has been run a little bit to reseat the rings again.
Old Jan 28, 2017 | 04:24 PM
Tedster9's Avatar
Tedster9
Mikes Carburetors has kits for just about everything, and free manual downloads for everything in .PDF form. He even answers email. There are other good websites too, but it's easy to remember.
Old Jan 28, 2017 | 05:01 PM
Silver54's Avatar
Silver54
Hey ted, thanks for the Tip about Mikes carbs! Awesome website with a great video to explain the differences between the carb kits!
Old Jan 28, 2017 | 07:56 PM
Tedster9's Avatar
Tedster9
Yeah I forgot to mention he has quite a few YT videos on disassembly and rebuilding. Carbs are pretty easy but there are tricks and a few gotchas on some of them. When a carb is setup and tuned it's a beautiful thing. If not, not so much.. lol
Old Feb 1, 2017 | 09:31 PM
Bessie's Avatar
Bessie
Just a note to say I fully agree with buying the extra 239, just don't pay much for it.
Old Feb 1, 2017 | 09:41 PM
Silver54's Avatar
Silver54
Would have been nice but their engine wasn't in the best shape. So we opted to just repair our own parts and continue. Waiting for the carb kit to come in now and should have the old girl whirling before we get too into spring time (I hope). Depends how much time off I will actually get to work in the shed
Old Feb 6, 2017 | 08:20 AM
abe's Avatar
abe
I am not an expert but isn't compression of 100 to 110 pounds good for an old Yblock?
Old Feb 6, 2017 | 08:40 AM
charliemccraney
No. On any overhead valve engine, 130 is about the minimum to be considered good. Below that, and you need to start thinking about a rebuild.
rico56
13
May 8, 2017 05:38 AM
1st Restore Project
Feb 7, 2008 05:48 PM
56KCFORD
Oct 6, 2006 11:08 PM
59'er F100
Jan 14, 2005 12:55 PM
denisontexas
Aug 25, 2003 06:49 AM
