Hey guys, my stage 1 Rosewoods came in today and I am planning on starting install in the morning. I just wanted to start a thread on it before I get started in case I have any issues. Any tips or special techniques that any of y'all have? Thanks guys!
120-140 INCH pounds is the correct torque spec. Also, remove the rear most one first so that most of your oil drains in the back cylinder. It'll be less for the other cylinders to get out. Let's see....rubber mallet...tap until you hear the tone change to a "ting"...make sure your cups are good and clean and in good shape....cover ALL of the holes where stuff can fall into...as Glenn said, LUBE GENEROUSLY before seating them to protect the O-Rings.I bathed mine in motor oil by hand and really really coated them. You can't use too much oil. Let us know if you run into issues. We are here to help.
Also, get a good flashlight and really look into the bottom of the injector cups. I almost put one injector in on top of the old copper washer that had fallen off the previously installed injectors.
Thanks for all of the replies! I've got them all in, what is the best way to turn the engine over to get the oil out? I tried the alternator bolt but the belt just slips... and I can't get enough leverage on the crank.
I bump the starter solenoid.... makes a mess so get a couple rags and cover the valve train or put a bolt or two on the valve covers.
If that's not a good method, someone tell me because I don't want to hurt this new motor and that's what I'm planning on doing when I install the new injectors.
Got it done and running! I used my 30" swivel ratchet to get to the balancer bolt, just had to find the right angle to come from and use some elbow grease. It did smoke a lot on the first run, I drove it about 20 miles. Without a chip it has quite a bit more power than it did... can't wait to get the chip.
