78/79 hood alignment?
Info like this and much more can be found in the tacked threads at the top of the page.
Hood alignment help posted here, Technical Info Hyperlink Compilation
Link to thread...click
originally posted by co425:
"Hood: Often the hood sits up above the cowl. To fix this, adjust the hinge where it mounts to the inner fender. Up at the front, and down at the rear. Reverse procedure to raise the rear of the hood. The hinges should be lubed with a good lubricant to operate properly or your alignment wont work no matter how long you play with it. (you should be able to almost throw the hood open with the flick of a finger)
Hood
Set everything in the middle, hood hinge to inner fender bolts and the hood bracket bolts.
I like to remove the latch at first so I can easily swing the hood open and closed."
1. To get the back of the hood down to line the cowl, loosen the 2 very back bolts on the hinge flange where it bolts to the inner fender and then have some one push the hood up standing in front of the truck while you tighten them back down, not a lot, might take a couple of movements to get it where you want it. Close the hood slow, DON'T SLAM IT, watch the back while it close's. Next, to get the gap the same all the way across you loosen the hood bolts on only the side you want to move, if your closing the gap, tap the back of the hinge arm with your rachet handle and the hood will move on its own, if you want to widen the gap, loosen the bolts and pull up on the back of the hood and tap the hinge arm on the front side and the hood will slide forward. Always close the hood slow after any adjustments to make sure its not gonna hit any where.
To tighten the front of the hood, there are 2 bolts on the hood latch that is slotted, you can see the slots if you look, loosen them and tap the latch down. If you go to much the hood won't latch, bring it back up.
2. Hood: Often the hood sits up above the cowl. To fix this, adjust the hinge where it mounts to the inner fender. Up at the front, and down at the rear. Reverse procedure to raise the rear of the hood. The hinges should be lubed with a good lubricant to operate properly or your alignment wont work no matter how long you play with it. (you should be able to almost throw the hood open with the flick of a finger)
3. Set everything in the middle, hood hinge to inner fender bolts and the hood bracket bolts.
If the rear of the hood is sticking up when it is closed you actually adjust the hood to open MORE. Either by lifting the front of the bracket or lowering the rear of the bracket. Sometimes both in combination. The center bolt acts as a pivot. Once that is done, and it can take a while to get everything nice and the gaps decent you then set the latch height.
If the hood is maxed out forward and is still interfering with the cowl you'll then need to loosen the inner fender to firewall horn bolts, inner fender bolt and radiator core support and move everything forward.
4. This is the driver side hinge. If you're hood is high compared to the cowl loosen the middle bolt and the rear bolt, then open the hood and it will push(rotate) the hinge down and towards the cowl.. Which is what you want. Look for the clean marks that the bolt head will leave behind for reference.
