Mpg expectations
Old Nov 5, 2016 | 05:43 PM
Norma stitz's Avatar
Norma stitz
Mpg expectations
Hi, so my truck has a few miles on it since the engine swap and my initial mpg numbers are a little lower than I had hoped. With my 35's and a untility bed empty it seems to be getting around 15mpg around town mostly.
Mpg related mods include:
4x4 SRW
35" mudtires
Mishimoto 200° stat
archoil 9100
atlas40 tune on my fcim
Blue spring update
Synthetic 5w-40 oil
Egr blocked
3.73 gears
Is this about all that can be expected? Is ere any way to get the numbers up without risking head bolt issues with more tuning?
Old Nov 5, 2016 | 05:45 PM
WatsonR's Avatar
WatsonR
In town driving... your about topped out. That should also net you 19-21+ on the highway.... not bad for a 10,000lb truck @ 70mph.
Old Nov 5, 2016 | 05:56 PM
Norma stitz
Cool. Yeah as long as it goes up on hwy I'm cool. In my experience though diesels tend to get similar hwy mpg as city.
Old Nov 5, 2016 | 05:59 PM
str8sixman's Avatar
str8sixman
id say your doing good. mine gets 13.3-13.5 avg hand calculated
Old Nov 5, 2016 | 06:02 PM
6.0only's Avatar
6.0only
Similar for me. Excursion. 14 city, 20 hwy. approx. could get better if I drove for mpg. Stock tuning. Not sure how, but MPG not much lower with 10k lb trailer.
You have FICM tuning, but PCM/TCM tuning could help MPG. Not vouching for non-stock tuning. Knobby tires and underinflation will hurt your numbers too, if that's applicable to your truck. Cetane-boosting additives may help as well. Synthetic / lower viscosity motor oil helps some.
Old Nov 5, 2016 | 06:08 PM
WatsonR's Avatar
WatsonR
Are you running T6 oil or other?
Old Nov 5, 2016 | 06:16 PM
Norma stitz
Running mostly t6 with about 35% delo LE full syn also.
Old Nov 5, 2016 | 06:17 PM
Norma stitz
Also this is a stick shift
Old Nov 6, 2016 | 04:32 AM
Mcrafty1's Avatar
Mcrafty1
4x4 SRW
35" mudtires
Mishimoto 200° stat
archoil 9100
Blue spring update
Synthetic 5w-40 oil
Egr blocked
3.73 gears
Is that mileage hand calculated or coming from the lieometer? I ask because it seems a little high for intown driving, a lot of us get less...it also seems a little low for highway travel... personally 13/17 is where I fall most of the time. Although I do just about enough highway driving to have my lieometer settle in around 15.5 if I don't reset it for long periods.
....My truck is also mostly stock overall, and 3.73 rears. that info used to be in my sig but back along I tried updating some things and when I tried saving it it wiped everything but what you see out? go figure.
Old Nov 6, 2016 | 08:08 AM
TxMav's Avatar
TxMav
I think that's pretty good considering the tires you're running. I'm stock and happy to get that when city driving. 18-20 highway.
Old Nov 6, 2016 | 10:39 AM
Norma stitz
Yesahand calc and corrected for tire diameter. I don't have a lie o meter on my truck. So I take my odometer reading and correct it for the tires which I figured is 8% via GPS. So I guess I'm doing okay then. We will see what the hwy says about it soon, just haven't really gone any big trips yet.
BII Plow Truck
Oct 9, 2020 06:08 PM
thelonius
Aug 13, 2017 11:08 AM
lwk362393
6.7L Power Stroke Diesel
Jul 12, 2013 08:30 AM
nickstl77
2009 - 2014 F150
33
Nov 19, 2012 07:36 AM
aridranger03
2010 - 2014 Ford SVT F150 Raptor
May 12, 2010 11:45 AM
