Borg warner trans problem
Old Nov 5, 2016 | 10:02 AM
Daniel Wray's Avatar
Daniel Wray
I have a 85' f150 with a 300-6 and a borg warner four speed with an overdrive. My problem is that it won't stay in third gear and second has a slight grinding sound while it's in gear. My question is why and does it need rebuilt and if so where can I find a rebuild kit for it?
Old Nov 5, 2016 | 10:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It's not a Borg Warner trans. You have the Ford RTS TS-OD Top Shift 4 Speed Overdrive.
Popping out of 3rd gear and grinding in 2nd gear, the brass synchronizer blocker rings are worn.
Old Nov 5, 2016 | 04:38 PM
Franklin2's Avatar
Franklin2
Is it a 4x4? Here are some listings of used transmissions in Va. 4x4 4 speed overdrive.
1987
Transmission Assembly
Ford Truck F150 76,000 A I025P $275 Brooks Auto Sales, Inc. VARA USA-VA(Oilville) Request_Quote 1-800-552-6783 Request_Insurance_Quote
1984
Ford Truck F150 CN 351,STD,MATCH UP 0 A 07023 $Call Shenandoah Auto Salvage, Inc. VARA USA-VA(Stuart-Draft) Request_Quote 1-540-943-2300 Request_Insurance_Quote
1987
Ford Truck 150 4 SP,4x4,Floor 0 A 14008 $Call Shenandoah Auto Salvage, Inc. VARA USA-VA(Stuart-Draft) Request_Quote 1-540-943-2300 Request_Insurance_Quote
1987
Ford Truck F150 CHECK ID 981129 $300 Salvage One Used Parts USA-VA(Coeburn) Request_Quote 1-276-467-1070 Request_Insurance_Quote
1987
Ford Truck F150 MT, (4 spd), Ford Od, 4X4 981790 $300 Salvage One Used Parts USA-VA(Coeburn) Request_Quote 1-276-467-1070 Request_Insurance_Quote
1985
Ford Truck F150 MBOX3,NTT,MT M0415 $Call American Auto Salvage USA-VA(Woodbridge) Request_Quote 703-494-7184 / 540-825-2571 Request_Insurance_Quote
1986
Ford Truck F150 4.9,5SP,4X4 H0512 $Call American Auto Salvage USA-VA(Woodbridge) Request_Quote 703-494-7184 / 540-825-2571 Request_Insurance_Quote
1985
Ford Truck F150 MBOX3,NTT,MT M0415 $Call American Auto Salvage-Formerly Phoenix Automotive-Store 2 USA-VA(Culpeper) Request_Quote 703-494-7184/540-825-2571 Request_Insurance_Quote
1986
Ford Truck F150 4.9,5SP,4X4 H0512 $Call American Auto Salvage-Formerly Phoenix Automotive-Store 2 USA-VA(Culpeper) Request_Quote 703-494-7184/540-825-2571 Request_Insurance_Quote
Old Nov 5, 2016 | 10:01 PM
rowdyredneck's Avatar
rowdyredneck
If its grinding during the shift to second it could be the blocking rings, but not the popping out of gear in third. The brass rings are only used to get the gear spinning during the shift for smooth engagement. Once the gear is engaged they become inactive. Popping out of gear could be caused by worn engagement teeth on the gear itself, worn or bent shifter fork, broken detent spring, or excessive main shaft end play. If its making a grinding noise all the time in second gear I would suspect either bearings or badly worn gears.
Big John Hance
Oct 5, 2022 09:40 AM
fordboy300
Dec 1, 2011 04:40 PM
cmorningstar01
Mar 13, 2009 01:04 PM
dspeer75
Feb 28, 2009 08:41 PM
displaytech67
Jan 17, 2005 05:28 PM
