Dialing in a fresh engine...
Then, as far as timing goes... If you see white smoke at the upper end, you are retarded. If not, play with it a little and see what feels better.faster - basically, what has the most power is generally pretty close to optimal timing.
If you advance it too much(within reason), you will lose power and it'll be really clattery.
Way too advanced and it won't even start. As far as damage, I'm sure you really could if you tried, but these engines are overbuilt; you'll know if you are more than a couple of degrees off in any case.
Play with it, see what happens. But without cranking up the fuel, you'll be running lean once you get some boost in there, so a more advanced timing(comparatively) will feel better.
Oh... Do you have a pyrometer yet? You'll definitely want one, especially with the added fuel you'll be running. It's not hard to get things quite hot going up a long grade towing, and that's the sort of thing that might burn valves if you let it get too hot for too long.
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
recommended procedure from several gear heads and motor guys for low wear , powerful motors ..
Mine is pre-turbo, in the up-pipe.
Mine:
Idles at about 180-200F if you leave it long enough.
In normal light driving, it's always moving around - goes between I'd say 800 down to 350 or so depending on conditions.
If I floor it, I'll hit around 800 in a couple of seconds, and then it climbs at like 30F a second beyond that(so a long hill, it'll start working it's way towards the danger point if floored).
If I hold the throttle just before the smoke point, it'll usually end up under 1,000F.
Cruising at 65MPH when the temps outside are like 60F, on flat level ground, in 6th gear(1700 RPM), it'll be between 500 and 600F. Obviously any downhills will lower it, any slight hills will rise it.
about the steady knock .. is this also while warm or only cold ..
if cold or hot it could likely be injector knock ..
word is that delphi injectors aren't very good .. but that's just hearsay .. i have no first hand experience to corroborate this .. but what i read was that the new delphi's are not great injectors ..
Make a reference mark on the pump and upper timing cover if the same pump is being reinstalled. When reinstalling the pump, realign the marks.
Inspect the fuel suppy line seals and replace them as necessary.
On E-vans, remove the RH seat for easier access. Also remove the fuel filter and housing as a unit for more room.
Remove the pump with the injector lines attached. On 7.3 engines there is a timing adapter on injector #1 (F-Series) or #4 (E-Van), hold this with a back-up wrench when removing that line.
Replace the injector return cap o-rings while the pump is off if needed.
On engines equipped with a turbocharger, remove the pump upper mounting stud to allow for more maneuvering room.
Remove and install the injection pump inlet fitting into the new pump; replace the o-ring if necesssary.
Seal the threads of the injector return line fitting with Loctite 515 Gasket Eliminator or PST.
Do not remove the injection pump outlet/check valve fitting and install it into the new pump.
On E-vans, adjust the FIPL sensor (E4OD trans) on the bench before installing the pump.
When installing the pump, use a phillips screwdriver or slim line-up punch to align the pump shaft with the gear. Start the gear screws into the pump shaft before installing the mounting nuts.
Start the injector line nuts onto the injectors before tightening the mounting nuts.
Don't mount the cold idle kicker solenoid until the pump timing has been set.
If the pump is being replaced, advance it counter clockwise as far as it will go then tighten the mounting nuts. This will make dynamic timing (while running) adjustments easier later. If dynamic timing is not available, set the pump to the center of its adjustment range, or line up any reference marks on the pump and timing cover.
If the twelve-point heads of pump shaft to gear bolts round off, they can be replaced with bolts from NAPA's u-joint hardware kit P/N 331-10.
Leave the injector lines loose until you're ready to start the engine.
When re-starting the engine, connect a battery charger to one battery and disable the glow plug system to prevent glow plug damage.
Connect a jumper wire from the positive battery terminal to the cold advance solenoid to help purge air from the pump.
Crank the engine over in 60 second intervals and tighten each injector line nut as fuel appears at each injector.
Recommend using a non-alcohol fuel conditioner to control water and algae and promote lubricity.
White smoke:
Caused by unburned fuel passing through the engine. Some white smoke is normal on cold start-ups.
Excessive white smoke could be an indication of inoperative glow plugs, loose injectors, low compression from worn rings or bent connecting rods, or coolant leak into the cylinders.
Black smoke:
Caused by excessive fuel for the amount of air drawn into the cylinders. Some black smoke on hard accel or at higher altitudes is normal.
Excessive black smoke could result from restricted intake or exhaust, inoperative leaking or weak turbo (if equiped), intake manifold gasket leaks (turbo), leaking or worn injectors, fuel return or supply restriction, advanced injecion pump timing or defective injection pump.
Blue or blue/white smoke:
Caused by insufficient fuel or oil consumption. Normal when engine is cold or idling for extended periods.
Excessive smoke could be caused by air in the fuel, contaminated fuel, loose or plugged injectors, thermostat stuck open, oil consumption, plugged crankcase depression regulator valve, retarded injection pump timing, or defective injection pump.
White smoke:
Black smoke:
