Results from Alignment
Old Nov 3, 2016 | 03:58 PM
robotunderpants's Avatar
robotunderpants
I was reading that toe-in anywhere from 1/16th to 3/16ths is ok
.11" = 1/8"
.07" = 1/16"
Not sure about the other specs however.
So how bad is it?
Old Nov 3, 2016 | 04:58 PM
dlburch's Avatar
dlburch
what are you working on? and I wonder why they didn't measure the caster?
are you having any problems with tire wear or driveability issues?
Old Nov 3, 2016 | 05:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Factory specs for your truck is:
Caster +3½° to +8½°
Camber +½° to +3½°
Toe in 1/32" out to 7/32" in
Old Nov 3, 2016 | 06:38 PM
robotunderpants
sorry, did not supply background info. I just replaced almost all of the front suspension. this is the first alignment of the truck.
Old Nov 3, 2016 | 09:29 PM
robotunderpants
Caster +3½° to +8½°
Camber +½° to +3½°
Ok, so I am learning this as I go. Please bear with me.
I have negative camber, as opposed to positive camber numbers which are spec as shown above. So on a scale of 1 - 10 how bad is my camber. I have no point of reference of how bad negative camber is, so I am curious.
Is this get off the road bad, or just make sure you rotate your tires bad?
Old Nov 3, 2016 | 09:43 PM
Rollingscrapmetal's Avatar
Rollingscrapmetal
My alignment was near double digits in cross camber (~8.5) it wasn't get off the road bad as those guys said my shocks were fine while I had three of them (busted shock mount) and I just kept driving for a very long time before I did anything let alone fixed it
It ate the tires but it still isn't that bad as the back are nearly as bad from the number of miles
Old Nov 4, 2016 | 07:11 AM
ubereal2's Avatar
ubereal2
Did you get an alignment to take care of a pull issue?
You have enough camber difference to possibly cause a pull to the right. Camber can cause a pull that will go towards the higher number, witch would be the trucks right side.
But, why didn't the tech do a caster sweep? Without that being done, there's no way, to see what is going on.
Old Nov 4, 2016 | 10:01 AM
robotunderpants
Yeah - not sure why I did not get caster sweep. I've only driven it a few miles since the alignment, and I was pretty pleased with how the truck was handling. Keep in mind, however, this was a total front end rebuild, so a lot has changed since I last drove the truck, so I am still getting a feel for how she handles.
Out of curiosity, how would one go about adjusting camber on these trucks?
Old Nov 4, 2016 | 10:16 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Special equipment to bend the axles. Not a job for the average tire store or garage. Now days you'll probably have to go to a shop that specializes in heavy trucks.
Although the shop manual says "the caster and camber angles are designed into the front end and cannot be changed".
Old Nov 4, 2016 | 10:18 AM
ubereal2's Avatar
ubereal2
Camber and caster can be changed by using a camber/caster bushing. They're measure in degrees, from .25 degrees to to 2 1/2 degrees, and turned to get the setting needed.
The upper ball joint stem goes through this, and can be turned to get the setting needed.
Old Nov 4, 2016 | 10:21 AM
ubereal2's Avatar
ubereal2
The bushing I posted a picture of is for a 4x4. I don't think I've seen that you've posted exactly what truck you have.
If it's a rear wheel drive truck, with a solid axle, then like Mike mentioned, the front axle would have to be bent to get camber.
Old Nov 4, 2016 | 10:24 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yup Unk Bob, his is 2WD.
Old Nov 4, 2016 | 10:28 AM
ubereal2's Avatar
ubereal2
Thanks Mike
I would think that would be adjustable using a caster camber bushing, unless that truck has King Pins in it, and I wouldn't think that it would.
Here's a 4x2 camber caster bushing.
Old Nov 4, 2016 | 10:53 AM
DB429SCJ's Avatar
DB429SCJ
With twin I-beams,could camber be changed by altering ride height (front springs) ?
Old Nov 4, 2016 | 11:01 AM
ubereal2's Avatar
ubereal2
That might, change camber a bit, but to do it correctly, a bushing should be installed.
Unk Bob
