Sheared lug nut problem
Old Nov 3, 2016 | 03:44 PM
csmith30005's Avatar
csmith30005
I keep shearing the same lug nut and keep replacing and the same one has sheared now for the 3rd time. Yes i know i have chevy wheels on a F250
Old Nov 3, 2016 | 06:00 PM
AlaskanWheeler's Avatar
AlaskanWheeler
Looks to me like your using all the wrong lug nuts. I could be wrong though...
Old Nov 3, 2016 | 09:04 PM
Macrobb's Avatar
Macrobb
I can't tell if the wheel is seated all the way against the backing plate. If it's not, and the lugnuts are effectively taking all the weight and strain... that would definitely explain it.
Old Nov 3, 2016 | 10:20 PM
wtroger's Avatar
wtroger
Those are the wrong nuts or the wheel hole is smooth wore out.
Old Nov 3, 2016 | 10:35 PM
Ford_Six's Avatar
Ford_Six
Wrong lugs, that wheel is designed for the 1 1/8" nuts.
Is it actually the same lug over and over? I am seeing two nice clean lugs in a row, with that third one broken. If that is the case, then you might have several damaged lugs that are fatiguing and breaking one at a time.
Old Nov 4, 2016 | 01:29 PM
csmith30005
the wheel holes are real worn and its swallowing up the nuts
Old Nov 5, 2016 | 02:08 AM
RSA7.3's Avatar
RSA7.3
If they are aluminum wheels the lug nuts are wrong. They should not be tapered but a nut with a built in flat washer I believe.
Old Nov 6, 2016 | 10:53 AM
shorerider16's Avatar
shorerider16
Definitely some funny business going on with the lug nuts there. I agree with Ford Six, I don't think it's the same one shearing off, it looks to me like that is the third different stud to break. The way things are it won't be the last either.
I wouldn't be driving that truck until it had a set of nuts that fit those wheels properly or a set of wheels appropriate for the truck.
Old Nov 6, 2016 | 11:46 AM
Macrobb's Avatar
Macrobb
I'm still wondering if the center hole is the right size; Chevy and Dodge wheels have the same hole pattern but smaller center holes by just a little.
If it was originally an aftermarket Chevy or Dodge wheel that was designed to be hub-centric(vs lug-centric), which would definitely be the case if you are using flat lugnuts... it might well not be sitting flat on the back.
There's probably a chamfer on the back side of the hub, so it mostly sits in place, but might well not be. And this would be why you are losing studs, due to torque on one side levering against the others. So if one side is tighter, the opposite side might well stretch and break.
Old Nov 6, 2016 | 06:13 PM
Charmalu's Avatar
Charmalu
The stain on the bottom lug/nut tells me the wheel has movement and is working.
or could be that one nut is loose.
Old Nov 7, 2016 | 08:37 AM
Jarkill's Avatar
Jarkill
Wrong nuts for sure! need tapered lugs for those
Old Nov 7, 2016 | 09:18 AM
wtroger's Avatar
wtroger
Those should be the 9/16-18 thread lug bolts. You need the big nut 1 1/16 inch nut with the long taper.
Old Nov 7, 2016 | 10:13 PM
Macrobb's Avatar
Macrobb
But the too-small lugnuts aren't making the studs break. If the threads stripped out of the lugnut, sure, but the lugnut obviously has enough strength to break the stud off.
A bigger lugnut will have more taper for the wheel to rest on... but it doesn't look like that's the issue here....
Old Nov 8, 2016 | 01:30 AM
shorerider16
I would say there is a good possibility that only a few studs are truly taking the load they way things are instead of being evenly distributed. As has already been said, it would be prudent to make sure the wheels are fully seating against the hub and not sitting out the studs due to interference in the centre bore.
Looking at the picture again, it looks like there are marks on the wheel from larger flanged nuts like you would find on hub centric wheel set up? Could also be marks from a socket on an impact? Curious as to what exact truck these wheels came off of.
Old Nov 8, 2016 | 07:32 AM
tjc transport's Avatar
tjc transport
i ain't rite
those are chevy wheels, which are usually lug centric. ford wheels are hub centric. the chevy wheels are depending on the ford lug nuts to stay on the truck. since the ford nuts are too small they are not seating properly letting the wheel wobble a bit and snapping the studs. either get the proper hub centric wheels for the truck, or get the proper lug nuts for the wheels. but even using the larger lug nuts may not solve the problem. .
