clearance lights broken
Old Aug 24, 2003 | 12:29 AM
morganburger's Avatar
morganburger
hello even with my lights on and on hi-beam my clearance lights dont work, does anyone know where the wiring goes to and what a possible fix might be or what i can do ? none of them work!
Old Aug 24, 2003 | 08:07 AM
theonlybull's Avatar
theonlybull
first. i'd pull them all off the cab(to acess the bulb) and check for voltage, with the parking lights on. they maybe all burnt out.
after that, you can look up inside the dash, behind the insturment cluster, the wire's should come down out of the driver's A piller. you can follow them from there.
Old Aug 24, 2003 | 01:10 PM
Mil1ion's Avatar
Mil1ion
The connection is behind the instrument cluster with a connector near the left side pillar above the headlight switch.
If my memory serves me right :
Look for a blue/red stripe wire or a plain Brown w.ire
Old Aug 25, 2003 | 09:24 AM
73Custom's Avatar
73Custom
Are you saying just the roof lights don't work, or all the park lights (front and rear) don't light up?
Marty
Old Aug 25, 2003 | 12:12 PM
Mil1ion's Avatar
Mil1ion
Whoops I assumed the roof clearance lights.
Maybe he means the side marker lights ?
Old Aug 25, 2003 | 05:05 PM
morganburger
well when are hte lights actually suippposed to come on
not during normal driving ?
when headlights are on ? or no
Old Aug 25, 2003 | 06:02 PM
Mil1ion's Avatar
Mil1ion
Which ones?
With the headlight switch in the any ON position , the following are illuminated:
Side marker lights
Roof Lights
Front & Rear parking lights on each side
Instrument cluster lights
huskyfan68
Feb 26, 2014 09:30 AM
automaticj5
Dec 14, 2013 11:06 AM
WINGNUT-
Oct 25, 2010 04:19 AM
kupiec20
Jul 1, 2010 04:40 AM
LesPaul
15
May 7, 2003 05:32 AM
