Bent steering shaft question
Old Nov 2, 2016 | 08:39 AM
greenmachine55's Avatar
greenmachine55
Hello and trying to pull my steering wheel off I accidently bent the end of the shaft slightly so now the wheel turns around crooked. The threads are still good. But, was wondering how to correct this problem. Any ideas? Thanks for all replies.
Old Nov 5, 2016 | 06:30 AM
3414's Avatar
3414
The shaft can be straightened, but it will be very difficult with it in the truck. Once it is out I would use a pair of V-blocks and a brass or lead hammer. I have also seen it done with a brass or lead hammer on a flat anvil, but that takes a bit more care to avoid damaging the shaft.
Old Nov 15, 2016 | 06:57 AM
matthewq4b's Avatar
matthewq4b
You will have to pull the shaft and if you are not confident straitening it any machine shop will be able to do it.
f-150 hot rod
1997 - 2003 F150
Dec 27, 2020 11:09 PM
woodsmoke
17
Apr 29, 2011 11:47 PM
twofoolish2b
Jul 1, 2007 07:10 AM
condor13245
Dec 14, 2004 09:44 PM
flyboyutah
Sep 12, 2003 06:59 AM
