Steering loose
Old Dec 14, 2004 | 09:30 PM
condor13245's Avatar
condor13245
Question Steering loose
I have a problem my steerign wheel is loose. I have tracked it down to a shaft that connects to another hollow shaft. I have tried the Dealership and they said that I have to but a whole new shaft for $300.00 I really dont think that is the solution. Does anyone have any suggestions.
Old Dec 14, 2004 | 09:44 PM
RR4E's Avatar
RR4E
are you referring to the slide shaft under the hood of the truck? If it has worn to the point of one shaft rotating inside the other, a wrecking yard donor might be your answer. Other than that, a good factory or aftermarket replacement is your only answer. I don't recommend trying to fab one, unless you know a good machinist who can get the correct steel, and shape it/machine it to correct tolerances.
