Help with Flathead Upper Rear Main Seal Replacement
Old Nov 1, 2016 | 09:52 PM
grandpas 51 f1's Avatar
grandpas 51 f1
I have to replace the upper rear main seal because mine is cracked. When I re-assemble do I have to re-align the crankshaft and camshaft timing marks or just drop it back in?
BTW I thought of this after I finished re-assembly.
Old Nov 1, 2016 | 11:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Sadly, I suspect you know the answer to that! Is the engine back in the truck now? Did you have the crank all the way out, or just dropped down a ways with the rods still on? It will probably be easiest to remove the timing cover and "correct" the timing by removing the cam gear and turning the cam.
Old Nov 2, 2016 | 07:32 PM
grandpas 51 f1
Thanks, yeah I figured I boo-booed. Luckily I was only one tooth off and was able to re-align easily through the timing cover. Thanks for taking time to re-assure my own stupidity.
emkay4597
Feb 6, 2011 10:22 PM
theFear
Mar 23, 2010 07:24 AM
xlttruck
Mar 28, 2009 01:08 AM
MatthewC
1978 - 1996 Big Bronco
Sep 16, 2004 08:39 PM
gtex
Sep 15, 2003 05:33 PM
