innie or outie?
Old Feb 6, 2011 | 06:33 PM
emkay4597's Avatar
emkay4597
innie or outie?
At this point its no sweat either way so which should I use an outer timing chain seal or an inner timing chain seal?
the future replacement idea seems obvious but which is better?
Old Feb 6, 2011 | 06:52 PM
bashby's Avatar
bashby
You mean the ft crank seal? they go in from the outside
Old Feb 6, 2011 | 06:57 PM
emkay4597's Avatar
emkay4597
well, this is what is adding to my confusion... im not at home right now other wise i would just go look at it. i saw this page and oddly it makes sense why you would want the outer one but whats the deal with the inner one? is it better?
Timing Cover Seal | 1986 Ford F150 1/2 ton P/U 2WD 6 Cylinders Y 4.9L 1BL | AutoZone.com
Old Feb 6, 2011 | 10:20 PM
ctubutis's Avatar
ctubutis
A guess would be there are two seals? Alternatively, perhaps different engines came
with different configurations over time, get the one you need.
Old Feb 6, 2011 | 10:22 PM
Rogue_Wulff's Avatar
Rogue_Wulff
I believe the 300 I6 uses a seal that goes in from the inside, which means pulling the front cover.
