56 COE project.. I need Help ;)
So ill start with what I have and where it is going.
2013 f59 pulled the 6.8L v10 and torqshift out of that monster and have planted it in a 56 COE.
Now the fun part! I am looking for opinions and options I might have to get the motor and trans running without using the factory wiring pulled out of the f59.
As far as the motor goes I've looked into a few places and they all have given me the "you need ours" or the "we don't have what you are looking for" speech but I would like some of the opinions of the people who actually have used their products. It being a v10 has anyone had success with a stand alone?
as far as the transmission goes everywhere I have look say that normally the torqshift was put behind a diesel and they don't have an application for what I am looking for. So I'm wide open on suggestions.
anyway thanks for you time..
-B-
ps if this thread isn't in the right place tell me
Unless you're willing to get into some weird custom setups and doing all the engineering yourself, you will probably never find anyone that makes what you need to get that setup going.
A recent build here at FTE involved an F150 Ecoboost being transplanted into a (I think) mid-60's F-series. What eventually happened was the builder decided to transplant the body onto the F150 frame and use the entire F150 chassis/frame/suspension/electronics. It worked, but was a huge amount of work.
One of the problems you're going to have is the speed sensor - the F-series uses the ABS sensor data from the rear differential to compute road speed. But given the new-ness of your V10 and it's electronics, I can't say for sure that it does or does not need the entire ABS system to be able to feed that data to the PCM.
But I don't want to stop you from trying what you're doing, so ... don't take this as a negative post
I'm just fishing for ideas so anything said will be useful.
