Forward front springs??
Old Oct 30, 2016 | 06:04 PM
vanspeed's Avatar
vanspeed
I have a 53 f100. I do not really want to lower it but that front axle not being centered bugs the crap out of me. I heard that the panel trucks had centered leaf springs. Is this true? If it is I could just find a set of those. If not can I re-drill the stock springs and move the axle forward?
Old Oct 30, 2016 | 06:30 PM
Branded's Avatar
Branded
You can buy the springs new with the pin in the forward location in either stock height or lowered. Below is the stock.
1953-56 Ford F-100 Front Spring Complete, Stock, Forward Center
Old Oct 31, 2016 | 08:35 PM
artscott61's Avatar
artscott61
Veteran: Navy
I had poised the question awhile back if maybe we could have it drilled forfward and just use a new center bolt. Can this be done ?
Old Nov 1, 2016 | 01:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
A F100 panel truck would not be any different than a F100 pickup. Both use the same axle and leaf springs.
Old Nov 1, 2016 | 03:00 PM
vanspeed's Avatar
vanspeed
I too would like to know if i could just have the springs re-drilled. Nothing is wrong with mine, would just like the wheels centered.
Old Nov 1, 2016 | 03:48 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Look at your existing springs. Are all but the main leaf drilled in the center already? and just the main leaf is drilled with the offset? I would expect that is the case, but I don't have a mid-fifty. If that is the case, I would have a new main leaf made, with the corrected hole location, and re-use the rest. Personally I'm not a fan of drilling springs, especially near the center pin, because it's a stress riser.
Old Nov 1, 2016 | 04:05 PM
vanspeed's Avatar
vanspeed
The springs on 53-56 were drilled 1.25 back from the factory so the tires sit towards the back of the opening. It was to make turning easier. I do not like the look, all the springs are drilled in the same spot, to locate the axle 1.25 back from center.
Old Nov 4, 2016 | 06:36 PM
vanspeed's Avatar
vanspeed
Has anybody re-drilled the stock springs? I have read about it being done on mono springs but not original springs.
Old Nov 5, 2016 | 01:18 AM
Kurt G.'s Avatar
Kurt G.
Guys I too hate the look of being to far back but I agree with Ross. I think drilling ANY more holes I the spring in not a good idea. I been thinking about getting a new main leaf and trying that...or just going to the Panther front end...LOL.
Old Nov 5, 2016 | 03:11 PM
vanspeed's Avatar
vanspeed
Am I wrong in assuming the whole spring pack is drilled? Is just the main leaf drilled?
Old Nov 5, 2016 | 08:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
They're all drilled. I don't know how the spring would behave with the other leaves asymmetrical tho.
Old Nov 6, 2016 | 04:53 PM
vanspeed's Avatar
vanspeed
I guess the only option is to buy new springs. What a bummer.
BelgianF100
Aug 15, 2015 07:49 PM
Dun Dreamin
Jun 23, 2011 02:02 PM
hotfalcoon
Sep 23, 2010 06:52 PM
pipman76
Jun 6, 2009 08:34 PM
emptyd
Mar 19, 2007 10:21 PM
