Sponsored by: Real Truck
What is this
Old Oct 30, 2016 | 12:15 PM
gabriell12123's Avatar
gabriell12123
What is this
I have a 1999 ford f250 super duty supercab and I'd like to find another one of these... can somebody give me some information (part number,name,etc.) Thank you
This is the driver side door thats missing the peice and with it it seems like the door osnt shutting all the way, and it scraping the paint when i go to close it.
Old Oct 31, 2016 | 09:12 AM
jetjockey99's Avatar
jetjockey99
I believe that is called a door bumper, you can just pull the one you have off and go to the dealer and match it. However if the door is not shutting, and is scraping paint I suspect that that is not your problem. You probably have an out of adjustment, or worn door hinge. Is there any play if you try to lift back end of the door with it open slightly? If so you need hinges. If it is tight either a hinge is sprung or just out of adjustment. If you can't determine which, a good body shop should be able to tell you and even fix it with out increasing the national debt.
GoldCo
Aug 5, 2019 08:34 PM
adams1492
2004 - 2008 F150
20
Oct 21, 2014 04:57 PM
clintonvillian
Feb 17, 2014 05:32 PM
Sparky83
Oct 11, 2012 10:34 PM
superduty4x4
57
Oct 29, 2008 02:39 PM
