Sponsored by: Real Truck
Battery not charging
Old Oct 29, 2016 | 10:04 AM
Skyline Drive's Avatar
Skyline Drive
I replaced my alt. because in the morning the bearing would squeak and the head lights flicker. It was a life time alt. warrantee from Adavanced. Put the new one in now it wont charge. Took it back and got another, same thing. Also replaced the starter relay and battery. I checked the fusible links and replaced a terminal connector. The wires look good. There is 12v on the alt lug and pins 1 and 3 on the connector with the key off. Turn key on and 12v disappears form pins 1 & 3. Also checked all fuses in both boxes. I ohmed out the wire harness from the alt back to the connectors, all good. What am I missing? This is a 99 f530 5.4l.
Old Oct 29, 2016 | 12:16 PM
r2millers's Avatar
r2millers
There's 12v on the alt lug be causes it connects directly to the battery. What voltage do you see with a vom when the engines running at that lug?
You should expect to see between 13.8-14.4volts running.
Also check at the battery knowing you'll have a slightly lower voltage due to wire resistance.
The battery should show about 12.6-12.8v if good and charged.
The other two wires simply notify your dash is not charging properly and "excite" the alternator at start up, unlike a 1- wire alt.
Old Oct 29, 2016 | 08:07 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
This is really really dumb but it's a true story... I had a pin back out of the wiring connector at the alt when I changed mine, and the way the wiring loom was taped I couldn't tell just by looking at it when it was plugged in, I had to remove the connector and look inside it. Make sure a pin didn't back out of the connector.
Old Oct 30, 2016 | 09:02 AM
Skyline Drive
Battery voltage is 13.45V. Started truck and measure 12.64V at alt lug. Bat voltage is now 12.55V. Battery light is still on dash
Old Oct 30, 2016 | 10:49 AM
99f350sd's Avatar
99f350sd
Battery 12.7 after flash off...lights on for 1 min..
Charging voltage 14.4 volts engine running.
Light on dash is needed for operation so that is good. Unplug alt.. light should go out. The regulator turns it off if alt is charging. Check single connector they go bad. Get alt checked on bench.
Old Oct 30, 2016 | 05:04 PM
Skyline Drive
Unplugged connector and no bat light on dash. I checked the single connector and there is continuity. Can I disconnect the bat cable to alt and check the voltage at the lug? Does the alt output without the cable connected?
Old Oct 31, 2016 | 08:23 AM
99f350sd's Avatar
99f350sd
Just make sure its connected to the battery..I would leave it connected.
Old Oct 31, 2016 | 08:26 AM
99f350sd's Avatar
99f350sd
Old Oct 31, 2016 | 08:54 AM
jetjockey99's Avatar
jetjockey99
DO NOT disconnect the battery at the alternator with it running, almost gauranteed to destroy alt if it is not already bad.
Old Oct 31, 2016 | 10:23 AM
r2millers's Avatar
r2millers
Initial static voltage at 13.54v seems a bit high but truck running at 12.64v at lug indicates the alternator isn't charging. You are now only seeing a true static voltage.
Expect the batteries to show 12.8v fully charged, 12.6 at 75% charged.
Carefully put a long screwdriver on the alternator pulley while running. You should feel a magnetic pull if operating.
While operating, expect to see approx 14.2-4v at lug. Not close!
New alternator next.
99superbooty
Nov 4, 2015 06:13 AM
Paul T
1983 - 2012 Ranger & B-Series
Dec 6, 2012 05:38 PM
ozzy_2_me
15
Sep 22, 2009 12:43 PM
scottfreeman
Electrical Systems/Wiring
Jan 3, 2007 04:33 PM
heathkiks
Jul 17, 2006 08:45 PM
