First fill up
Old Oct 31, 2016 | 03:49 PM
EightySecond's Avatar
EightySecond
I filled up this morning, gauge showed 38 miles to empty and it took 43 gallons.
Old Oct 31, 2016 | 04:15 PM
coolidge54's Avatar
coolidge54
What about steeper inclines, the tanks are long front to rear it may be possible to run out of fuel with the few remaining gallons sloshed to one end or the other.
Old Oct 31, 2016 | 04:55 PM
SBC's Avatar
SBC
Sounds like the long boxes are a little closer to accurate.
Old Oct 31, 2016 | 05:02 PM
Rasalas's Avatar
Rasalas
Originally Posted by Uzumati
Guess it comes from years in the fire department but i always fill up as soon as she hits 1/4 tank, 3 fill ups so far and all have been 24-27 gallons on the 34 gal tank
Have always done the same thing. My '01 has a 39 gallon tank. 1/4 tank left means 30-32 gallons. Just the way it should be. But now I will be down to a 34 gallon tank which read incorrectly and will wind up fueling 30-40 % more often if I live by the gauge. This is wrong of some clipboard **** to determine that I cannot know the correct time to refuel the vehicle. The group who started this probably came out of some division of the government which assure us to be too stupid to know empty is empty.
Old Oct 31, 2016 | 05:36 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
The division is probably run by housewives
Old Oct 31, 2016 | 05:44 PM
srkr's Avatar
srkr
Ok, so let's say, I want to figure out exactly how many miles till she starts choking....I have always been told it is not good at all to run out of diesel.
That true?
I know you have to turn key on and off to prime pump....but what if it is a push button start?
Old Oct 31, 2016 | 05:48 PM
gascan's Avatar
gascan
Originally Posted by srkr
Ok, so let's say, I want to figure out exactly how many ,lies till she starts choking....I have always been told it is not good at all to run out of diesel.
That true?
I was about to ask the same questions... What happens if I run until it does start starving for fuel, then what?
I would prefer for someone else to test this rather than me!
Old Oct 31, 2016 | 07:14 PM
screwy's Avatar
screwy
I would never want to run the HPFP out of fuel, they depend on the diesel for lubrication and it's very messy if they let go. My theory is it's only the diesels with the extra buffer built into the gauge for that very reason, but it's just a theory at this point.
Old Oct 31, 2016 | 08:17 PM
wb6anp's Avatar
wb6anp
Also the injectors require fuel for lubrication, you run out of fuel you could destroy your injectors.
Old Oct 31, 2016 | 09:30 PM
Falkirk18's Avatar
Falkirk18
I've run two full fuel runs, and I'm no expert, but we have a problem. I have a 34 gallon tank, and I showed 23 miles to empty on the first tank, and 18 miles to empty on the last one, and didn't get more than 27 gallons into the tank either time.
Any guesses on if it's a software issue, or a issue with the equipment in the tank?
Old Nov 1, 2016 | 09:08 AM
srkr's Avatar
srkr
Thumbs down
Yup, same problem here.
What's going on?
I had 17 miles to empty, filled it up to the neck,..saw the diesel and barley got 27 gallons. Are we sure it's a 34 gallon tank? Does not make sense...even at 10 mpg that's 70 more miles. I am averaging 16 mpg in city..so that's 160 miles as a safety net.......... .
I want answers from
Old Nov 1, 2016 | 09:45 PM
srkr's Avatar
srkr
Anyone else?
Old Nov 1, 2016 | 10:49 PM
  #28
RJC2's Avatar
RJC2
Question, Do the 2017s have the problem filling the last 5 gallons like the older trucks have? (last 5 gal. take 10 minutes to fill)
Old Nov 1, 2016 | 11:30 PM
  #29
Kenv's Avatar
Kenv
No....the last 5 gallons fill just as fast as the first gallon....did so also on my 2011. You must be thinking way back..as the 6.7 has never done this to me.
Old Nov 1, 2016 | 11:33 PM
  #30
Kenv's Avatar
Kenv
Falkirk....I mentioned this in a post a few weeks back. To see if someone could physically measure the size of the new 34 gallon tank on the '17 and measure a 29 gallon tank off of a short bed 2016 to see exactly what we are seeing dimension wise. I think there is a bigger problem then has been brought to light. Maybe yes..maybe no big deal....but why are these bigger tanks not taking more diesel when "Empty"????
