Thinking of ordering these .Black oval for my RR truck. If I had blue jeans like I was going to get, i'ld get blue ovals. Seems a good price? https://www.sharptruck.com/cart...also I'm thinking of getting 285/75-18's.....anybody have issues with oversize tires hitting any of the flap/mounts?
I was set on getting the 6.7L logo flaps, but SharpTruck couldn't respond to my email. I went with DuraFlap. Top notch customer service. They offer logos, too, or custom logos.
What are most people getting size wise for SRW? 23"-23" or 23"front-26"rear, 26"-26"? I saw a post that the Ford Gatorback is 23" front - 26" rear and wondering if that is the path I should go. I was going to go 23"-23"
I went 26/26 fits good. BTW, big shout out to sharptruck for replacing my two scratched stainless plates!!
Well anyone crazy enough to spend $85,000 on a pickup better not balk at $500 mud flaps. So I am a crazy F450 owner and I did spend $600 on my Gatorbacks and am quite pleased with them and the quality is significantly better than anything else out there.
I 2nd that... As I too am a crazy proud F450 owner...
where are the no drill brackets located? And for everyone else. I talked with my dealer and i can get a set of 2 gaterbacks for 170. Not sure where some guys are seeing 600 for the set of 4. Just throwing out my 2 cents
I am running the 26 front 26 rears and they fit and look great. I have 325/65/18 BFG KO's on the stock Lariat rims with no lift and they very slightly touch the flap at almost full turn. I run winters on steelies but before I put the summers on I will hook a stainless cable to the fronts to hold them back about 1/2 inch just to be safe.
I'm hoping to order a 2019 F350 DRW later this year, I'll be running the DuraFlaps on it. Just not a fan of the Gatorbacks or the extra no drill bracket you have to buy. I'm currently running DuraFlaps on my '11 F350 DRW and have never had a minutes trouble with them, they've been on since day one and 171K miles later. To each they're own, that's why there are options out there.
Originally Posted by Carnac22
Found the Gatorback Ford F-250 2017 blue oval front 23", rear 26" set with mounting brackets on sale at Sharptruck.com for $420.
Seemed like a good price - ordered a set. Looking forward to getting them on.
Jim
I’m running 325/65-20 which are a little over 35 and yours are a little under, but the same width. .I have a 2 1/2” level installed. They may work. Hopefully someone else will chime in.
^^^ x3. The "6.7 powerstroke" gatorbacks on the back and "blue oval" gatorbacks on the front made a fine addition to my F450 King Ranch.
The backs are a pain to install. They should have had the needed 10 slots pre-cut IMO. BTW, a jigsaw with a narrow blade created the slots between each pair of holes I drilled quick and easy.
