Ford Emblem nuts
Old Oct 28, 2016 | 08:21 AM
70FE250's Avatar
70FE250
Ford Emblem nuts
Is there anywhere online that sells the nuts for my Ford hood letters and the emblem on the side of the hood? I wish to mount all of them back on but I somehow lost the bolts to mount them. Or else is there some bolts I can pick up at menards or lowes that work? I haven´t been able to find the bolts yet without buying everything new
Old Oct 28, 2016 | 08:32 AM
Brian1971f100's Avatar
Brian1971f100
Hit the bone yard. Any ford hood letters should use the same nuts you are looking for
Old Oct 28, 2016 | 09:29 AM
70FE250's Avatar
70FE250
I have tried that also. Unfortunately, North Dakotans consider the emblems a treasure apparently and I could not find any lettering or bolts to use, also considering the fact there´s maybe 6 fords with the suitable lettering at the closest yard to me
Old Oct 28, 2016 | 09:31 AM
orich's Avatar
orich
I found some emblem nuts on ebay. I guess you have not check online.
Also saw some of the rubber backed emblem type nuts at Lowes & Ace hardware type stores.
Orich
Old Oct 28, 2016 | 09:33 AM
70FE250's Avatar
70FE250
Orich
There´s a thing about me, I have an unnatural distrust for ebay so I usually avoid it at all costs. Had a friend get scammed over a part for a vehicle so I try to stay away. But maybe I will try ebay out for these
Old Oct 28, 2016 | 09:39 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Try AMK. Put in your truck info, and hit submit. If you look down this list, you will see a listing for NAMEPLATES @ HOOD SIDES, these might be what your looking for. Not sure if those same nuts will work for the letters on the hood.
Ford Fastener Kits
Old Oct 28, 2016 | 10:45 AM
Brian1971f100
So I guess the proper name for these are "speed nuts" I see summit racing has 3/16" speed nuts looks like they are about $2.00 each. Ouch that's pricey they should be a 20 pack for that price. They are listed as emblem nuts. OER Emblem Speed Nuts 11501047
Old Oct 28, 2016 | 11:06 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
I wonder if you could find these at an Ace Hardware store, they carry a lot of automotive fasteners. Even Lowes carries some.
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
373888-S78 .. 1/8" Spring Nut-FORD Letters to Hood / Obsolete
1970/72 F100/750 & Econoline.
No Ford dealer or obsolete parts vendor has any.
371024-S7 .. 1/4" Self Threading Nut=Emblem to Hood Side / Obsolete
1968/72 F100/750.
OBSOLETE RELIABLE PARTS in Nashville GA has 3 = 229-686-5101.
Old Oct 28, 2016 | 11:07 AM
JEFFFAFA's Avatar
JEFFFAFA
For 70/72 the hood letter 1/8" spring nuts were part number 373888-S7-8. The hood side emblem nuts were part number 371882-S7. There are none of either of these on my locators.
And OP, not trying to beat you up but you need to call a part the correct name if you are ever to find it. Bolts are male. Nuts are female.
Old Oct 28, 2016 | 11:22 AM
rechinca's Avatar
rechinca
Yes you can find these at ACE Hardware or any decent hardware store that sells nuts, bolts, etc by the piece.
Old Oct 28, 2016 | 02:46 PM
70FE250's Avatar
70FE250
Yes, I did not get any sleep last night so my brain is operating at 2% how it normally does. I found macs sold the nuts online so I may attempt to purchase some if they are the right size
Old Oct 28, 2016 | 05:32 PM
lilorbie's Avatar
lilorbie
Ford Emblem nuts
70FE250 if you have a PPG paint store close to where you live they have what you are looking for. i needed some barrel nuts to hold the letters across the front of my 67, they said here their free. now you might not get that good of a deal, but you never know.
Old Oct 28, 2016 | 05:52 PM
artscott61's Avatar
artscott61
Veteran: Navy
go to a body shop
PapaBearYuma
Jan 26, 2017 06:16 PM
52 Merc
Jan 16, 2013 10:00 AM
medicpg
Jul 31, 2008 02:06 PM
sparky
39
Nov 1, 2006 06:07 PM
