400m c6 size
Old Mar 21, 2013 | 04:20 AM
Jeremys1088's Avatar
Jeremys1088
400m c6 size
I have a 78 f150 that needs a new c6 trans. I was wondering if I need one for a big block or a small block? Any fees back would be greatly appreciated.
Old Mar 21, 2013 | 07:00 AM
ibleedblue1385's Avatar
ibleedblue1385
You need one with a big block bell housing to bolt to the 400.
Old Mar 21, 2013 | 09:56 AM
Jeremys1088
So if I were to get one from a 460 I'd be in good shape
Old Mar 21, 2013 | 10:00 AM
ibleedblue1385
yes but look for one with the same length t-case adapter.
Old Mar 21, 2013 | 12:56 PM
Jeremys1088
Those are bolt on right?
Old Mar 21, 2013 | 01:24 PM
ibleedblue1385
Correct.....
Old Mar 21, 2013 | 03:36 PM
J ballan's Avatar
J ballan
Yep you need one with the same bellhousing pattern as a big block. Just remember that 2x4 and 4x4 trannys are different and no 460 came in 4x4 until the 80s. Also make sure there is bolt holes around the shift shaft for the NSS. Good luck.
atomicjoe23
Jan 5, 2012 03:39 PM
awfulaggravated
Mar 8, 2008 07:23 PM
JoseCuervo
Feb 13, 2005 07:54 PM
ptmilan
Jan 24, 2005 05:26 AM
rick90yj
Jun 1, 2003 04:19 PM
