Separating adhesive on transmission plate
Old Oct 27, 2016 | 01:36 PM
Frozen_Joker's Avatar
Frozen_Joker
95 F350 here. When I did the clutch in my 96 F250, the adhesive was pretty worn down, so the transmission plate from inside the cab was easy to remove. Not the same for my 95 F350. The crap is on there pretty good and I can't cut it apart as none of my knives can reach across the width of the contact between the plate and the cab. Is there an easy way to separate this? I cannot access the top four bolts of the transmission without removing this plate. I was thinking a little bit of heat, warm the adhesive up. I'm assuming its window urethane, has the same texture. Fast help appreciated. I'm not finding anything on the web to help me here.
Old Oct 27, 2016 | 02:12 PM
Frozen_Joker
And heat works pretty damn well. Take it to the underneath and it doesn't take much. Lol
Old Oct 27, 2016 | 04:15 PM
Diesel_Brad's Avatar
Diesel_Brad
Pry it up. Once you break the seal you will be able to pull the rest up
seansolo7144
Appearance & Dress-Up
17
Mar 22, 2020 07:28 PM
rannaska
May 23, 2016 10:20 AM
2l8-iwon
Jan 18, 2013 07:45 PM
f1drivr
1966 - 1977 Early Broncos
Jul 9, 2003 11:15 AM
