Cam swap decision
Old Oct 26, 2016 | 11:02 AM
'89F2urd's Avatar
'89F2urd
Crane 444211 or comp xe258
Old Oct 26, 2016 | 11:33 AM
Mudsport96's Avatar
Mudsport96
Originally Posted by rla2005
1994 was the switch over to MAF for 5L equipped trucks. I have never heard of a 1995 F150 with a 5L engine and Speed Density. Not to say it did not happen, but very rare IMHO.
​​​​​​​The1995 5 speed trucks are ALL speed density. Unless there is a unicorn EEC IV truck somewhere. I've looked for years for TRUCK MAF 5.0 5 SPEED computer for my 5,8 swap. None.
Old Oct 26, 2016 | 11:46 AM
rla2005's Avatar
rla2005
Now we have more to the story. Thanks for the clarification Mudsport
Old Oct 26, 2016 | 11:49 AM
Mudsport96's Avatar
Mudsport96
Very welcome. Its a pain in the butt not having a simple maf swap. This is the main reason the five speed guys do the mustang EEC swap.
Old Oct 26, 2016 | 11:59 AM
GoinBoarding's Avatar
GoinBoarding
On a related topic Mudsport, do you happen to know if there are any EEC-V MAF PCMs from 5.0L 5spd trucks (1996 for OBDII)? I suspect yes but thought I'd ask. My E4OD won't last forever, I'm trying to plan for the future and looking at all possible options.
rigsboo's Avatar
rigsboo
The crane is about $340 alot more than i wanna spend...what do yall think about this?
https://m.summitracing.com/parts/cca-35-349-8/none/images
​​​​​​​any other recomendations?
Old Oct 26, 2016 | 12:57 PM
Mudsport96's Avatar
Mudsport96
Rigs, the revue right on summit says it all. Probably be OK in a light car, but a heavy truck may see issues.
Drivability and Power
Summit Racing Verified Purchase
For you foxbody guys, this Cam has great power and is very drivable. no idle issues (using stock tune in my 93 foxbody) and sounds great. bucks just a LITTLE bit (very little) at low RPMs. goes exceptionally well with 24# injectors and GT40 heads. makes for a excellent street machine!!!! will buy again.
​​​​​​​Goinboardin, I haven't really looked into the OBD2 EEC V stuff since it would be an entire rewire of my truck. Maybe Conanski will know..
Old Oct 26, 2016 | 02:07 PM
'89F2urd's Avatar
'89F2urd
https://m.summitracing.com/parts/cca...-8/none/images
The profiles of the rollers are worth the money. They have aggressive ramp rates (rapid opening and closing of valves) combined with the decrease in friction. Cams are the biggest pains to swap, misewell cough up the extra dough for the better cam and forget about it.
Old Oct 26, 2016 | 05:23 PM
Conanski's Avatar
Conanski
Rigsboo, based on how you plan to use the truck I suggest you leave the stock cam in there and just add 1.7 rockers and longtube headers. Any cam with more duration than the stock F4TE cam will result in a loss of low rpm power with the 5.0, that is just the nature of the beast with this motor. I had the Comp 35-349-8 in the 5.0 in my old '90 with longtubes and MAF and it couldn't even chirp the tires.. completely gutless below 2000rpm.
Old Oct 26, 2016 | 07:07 PM
rigsboo's Avatar
rigsboo
What about the lunati 20350611 its got a good review on summit and it says idle to 5000 rpms...i belive you are giving me the best answer im not questioning you its just i dont wanna take all this out and put it back then later decide i wanna do a cam swap ya know?
Shwan_89HD
Oct 4, 2013 05:29 PM
fomoconate
May 19, 2009 09:44 PM
77 Ford Mudder
Mar 30, 2008 02:30 PM
Jrock909
Dec 29, 2006 12:26 PM
