Sponsored by: Real Truck
Over heating???
Old Oct 25, 2016 | 07:35 AM
BIGIRA's Avatar
BIGIRA
Over heating???
Ok so here here goes I have a 1999 f250 super duty with 5.4 triton it seems to be over heating but the gage stays in the normal operating temperature range. I just changed the water pump. Could it be the thermostat and Would it hurt to remove the thermostat until I can get one
Old Oct 25, 2016 | 09:10 AM
Boaterguy's Avatar
Boaterguy
What overheating symptoms does it have? Boil over? Steam?
Old Oct 25, 2016 | 09:13 AM
BIGIRA's Avatar
BIGIRA
It just seems to be boiling over I pulled the thermostat out and it is still doing it.
Old Oct 25, 2016 | 09:15 AM
don123's Avatar
don123
How's the radiator?
Old Oct 25, 2016 | 09:22 AM
BIGIRA's Avatar
BIGIRA
It seems to be circulating fine
Old Oct 25, 2016 | 09:25 AM
don123's Avatar
don123
Check all your radiator hoses,radiator cap and fan if you haven't already.
Old Oct 25, 2016 | 09:27 AM
BIGIRA's Avatar
BIGIRA
Hoses are all new
Old Oct 25, 2016 | 09:31 AM
don123's Avatar
don123
radiator cap can cause problems.
Old Oct 25, 2016 | 10:31 AM
Boaterguy's Avatar
Boaterguy
Make sure when you replaced water pump there are no air pockets in the cooling system. Then when the motor is cool, try to turn the fan by hand, there should be some resistance, if not replace the fan clutch. You can test the thermostat by putting it in a pan of water with a thermometer. Place on the stove and start heating the water. Around during 190 degrees you should see it open.
BIGIRA
Oct 25, 2016 07:34 AM
F-250 WARHORSE
Mar 2, 2013 12:05 AM
t.j.g.
Jan 18, 2005 08:46 PM
fordmando
Mar 21, 2004 12:13 AM
dkchristensen
Aug 1, 2003 12:05 PM
