6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Intermittent rough idle
Old Oct 24, 2016 | 06:20 PM
fearfactory's Avatar
fearfactory
Ok, I have another issue with me truck. Every now and then while driving around, the engine will start running rough like it isnt firing on all cylinders. There are times it will smooth out within a minute or two, and other times I have to let it sit overnight before for it to run smoothly. This has been going on now for a year, but like I said, it has been intermittent.
In the past when this has happened, I could never pull any codes using sct x3 programmer. Well today the issue came back, so I hooked the programmer up and finally got some codes.
Here is what I got:
1. P0269 - Cylinder 3 Contribution Balance
2. P0403 - Exhaust Gas Recirculation Circuit
3. P0405 - Exhaust Gas Recirculation Sensor A Circuit Low
4. P0611 - Fuel Injector Control Module Performance
Now the run down on my truck. Its 2004, with 142k miles, egr delete and a tune. ICP sensor reads .26v with the key on and .88v at idle. I tested the FICM, and I got 58.5v with key on and 58.8v at idle.
Old Oct 24, 2016 | 06:47 PM
fearfactory
Can a mod, please delete this thread. I mistakenly posted this in which I thought was the 6.0 forum. Thanks
Drew76924
Mar 14, 2019 03:33 PM
fearfactory
Oct 24, 2016 09:06 PM
timmyboy76
Nov 17, 2011 10:12 PM
wba3107
Nov 24, 2009 05:24 AM
ham4ever
18
Apr 4, 2004 10:53 AM
