No Throttle Response in Gears After Injector Install
Old Oct 23, 2016 | 03:14 PM
Burgess090906's Avatar
Burgess090906
I just completed installing rebuilt injectors in #2 and #4. for the 2nd time. The first set had failures with those two. After assembly, the engine runs rough which is understandable considering the air introduced. I can run the RPMs up while in neutral or park, however; there is almost no throttle response in drive or reverse. It will barely move and only slightly raises the RPMs. I am unable to drive it to get the air out until this particular issue is solved.
Prior to the tear down for #2 and #4, the throttle response was fine.
Current Codes:
P0272 - I am hoping this would go away once the air is gone.
Software:
AE w/ Ford Bundle (New to me)
Buzz test is fine
Power balance looks great
FICM logic and power are good
Skills:
DIY w/ limited electrical knowledge
Recent Mods in last 300 miles:
New heads
ARP studs
ICP
IPR
FICM w/ Atlas 40 from FICMreapir.com
Injector harness
HPOP
Chemical flushes
Oil Cooler
Leak Proof Ball Tubes
Stand Pipes
8 Rebuilt Injectors
Batteries
MAP Sensor
New Turbo w/ updated supply and return
All associated gaskets and orings replaced with the above
All OEM where available, except injector rebuild service
Old Oct 24, 2016 | 06:48 AM
Burgess090906
The throttle response came back last night when I started it up again. I do not know why or how. I was able to drive 10 miles. I had response at all throttle positions.
I still have the P0272 issue, but I have started a new thread on that subject.
Old Oct 25, 2016 | 11:59 AM
Burgess090906
Okay. Thank you for the help.
Old Oct 25, 2016 | 01:56 PM
run6.0run's Avatar
run6.0run
I will bite,, and by rebuilt injectors,, you mean from an online retailer?? Either go ford on the injectors,, or just leave them alone. IMHO,, all those online injectors have about an 80% success rate,,, meaning 7 out of 8 might be good. But either way,, the online ones are ALL JUNK!!!
Old Oct 25, 2016 | 02:56 PM
Per4mance's Avatar
Per4mance
Damn Ant, nothing like sugar coating it. LOL, you must be following in my foot steps.
Old Oct 25, 2016 | 03:19 PM
Burgess090906
I sent my injectors to the company for the service below:
completely disassemble the injectors including the spool valve
clean everything in an ultrasonic cleaner for 6+ hours to remove carbon buildup
recondition nozzles
replace all of the o rings
install new springs
replace check ball
replace high pressure oil rail O ring
install new copper washers
newly honed spool valve housings and new oversized spool valves are installed in every injector no more stiction problems
I know it is not a reman OEM, but the total cost was $750 for all eight. They have been extremely prompt when sending replacements, even before sending the failures back. I have mixed feelings about what I would have done after the knowing about the failures. At the time, I did not have any injector issues, I was only having them reconditioned while my heads where off. I have not quite caulked this up to a bad decision just yet.
IDI-Charlie
23
Oct 28, 2020 08:14 AM
SMS888
Aug 29, 2011 10:15 PM
whenry912
Dec 20, 2010 10:54 PM
strange
General Diesel Discussion
Apr 8, 2007 10:56 PM
Hamberger
Feb 15, 2007 11:15 AM
