04 Expy stalling issue
I've got 3 ford trucks of various types and vintages and have gotten SO MUCH good information from this site although this is my first post asking for help.
2004 Expedition XLT 5.4, close to 200k on the clock. Truck runs and shifts great. Problem started with in town driving but is now doing it at highway speeds. So intermittent that I can't find anything obvious! It will go 500 miles and run beautifully. Then I'll drive 50 miles and it will die 6 times. Electronics always work. It's not a battery cable. At speeds over 10 mph, I can usually shift into neutral when it dies and it fires up on its own. Without turning the key. In parking lots or at stop lights, I have to pull over and crank it manually a few times to get it to restart. It never hesitates or sputters. Just straight up cuts out.
Since this truck has so many miles, I have started cleaning everything and throwing parts at it. Here is what I've done so far: Removed and cleaned throttle body, MAF. REPLACED: IAC, TPS, PCV. I have visually inspected all vacuum lines and also used a can of starting fluid to spray them all when the truck is idling. All to no avail.
I bought this truck a few months ago and the previous owner always had it serviced at the dealership. The fuel pump was replaced sometime in the last year. Fuel filter looks newer so I have not replaced it.
Has anyone else had this issue? The next step I'm taking is disconnecting and cleaning all the electrical and computer control plugs and sockets.
Thank you you anyone who can offer some experience!!
Thank you you anyone who can offer some experience!![/QUOTE]
