Ignition gremlin
Old Oct 22, 2016 | 09:02 AM
Wayne Pittman's Avatar
Wayne Pittman
Ignition gremlin
I have a 92 f-150 XLT 4x4 with the 5.8 and E4OD tranny. Here's the problem. It won't start when temps drop below 60 overnight. When I turn the key I hear the fuel pump engage, but the engine won't turn over. The battery is fine, it has a new starter and starter relay. It will start and run if I jump it off the celinoid. However if you drive it the odometer doesn't work and it shifts erratically. This is only in the mornings, once temps warm up during the day it starts and runs perfectly. Anyone ever dealt with this?
Old Oct 22, 2016 | 04:44 PM
rla2005's Avatar
rla2005
Ignition switch out of adjustment or bad is my first guess. It's located on top of the steering column just under the dash.
Old Oct 23, 2016 | 08:39 AM
Robert Long's Avatar
Robert Long
cheack your ground cable
makthenif
13
Jan 20, 2014 07:50 PM
Malorkis
Feb 2, 2011 01:54 AM
durbancic
May 10, 2008 11:52 AM
dwill49965
1983 - 2012 Ranger & B-Series
May 14, 2005 01:00 PM
fosdick
Nov 16, 2003 07:46 AM
