Painting rusty core support question
Old Oct 21, 2016 | 02:12 PM
fordguy2100's Avatar
fordguy2100
So I've been sanding down my core support and have most of it down to clean metal however there are some hard to reach areas with rust and paint and some pitting from rust. What's the best way to paint this support so I don't have rust come back? I've put a lot of elbow grease into this and really don't want to have to do it twice. Should I put some sort of rust converter on the rust I can't get to then primer and paint? Thanks for the help, paint and rust aren't my forte
Old Oct 21, 2016 | 02:39 PM
mikeo0o0o0's Avatar
mikeo0o0o0
You could have the support sandblasted, that would get to the hard to reach areas. If not, yes, treat the rusted areas with a rust converter before painting.
Old Oct 21, 2016 | 02:53 PM
kwe45919's Avatar
kwe45919
Having it blasted in the first place is hind sight......if that option is available to you, get it done every time. Worth it in my opinion so your not spending hours getting "most" of it off. Around here that'd cost about $50 to blast at the local shops....if you don't have local shops, spray the rust crap and get many different size brass and stainless bottle brushes to help get into those areas and get crap out. Then either epoxy primmer or use rustoleum type primmer to seal in anything you couldn't get to before painting.....
BTW....good job. That's a lot of time and elbow grease used to get the core support looking that good...
Old Oct 21, 2016 | 03:01 PM
speedfreak78's Avatar
speedfreak78
I think I see heavy corrosion and possibly a crack in the second to last picture, which could mean rust in the internal structure coming through.
Short of cutting it out and replacing it, the only real way to stop it is to submerge the whole thing in a rust neutralizer. Build a frame of 2x6s to contain it, line it with plastic or a tarp. Get some phosphoric acid based rust solution. I use Kleenstrip prep and etch, instructions are on the bottle how to use it. I think it gets mixed 4:1 water/ etch and then soak for 24 hrs. Pull it out, rinse and blow dry. It'll leave a zinc coating on the steel, ready to be scuffed and primed.
Using a rust neutralizer on the exterior, then oiling the internal parts after paint would probably keep it at bay, but it'll always be there, slowly growing.
I HATE RUST!
Old Oct 21, 2016 | 03:08 PM
speedfreak78
Ft
I just added a 120 gal tank to my compressor and picked up a blaster. I'm going to start doing this smaller stuff, no frames or bodies, on the side come spring, I just need to setup an enclosure to work in. None of the blast places around here seem to want to touch things like this, or they want stupid money to slide it into their production run. If I can make some money to fund the projects and help out some fellow enthusiasts, seems like a win/win
Old Oct 21, 2016 | 03:14 PM
c391d's Avatar
c391d
I just had mine blasted a couple weeks ago. Only cost $35. Then sprayed it with Eastwoods satin chassis extreme black. Turned out great. Well worth it on a piece like the radiator support.
Old Oct 21, 2016 | 04:53 PM
fordguy2100
I don't have any local shops around me, might see if there's one around my folks. Was trying to do it myself/on a budget. I thought it would cost a lot more than that. I'll do some calling and see. What looks like a crack" is actually the end of another piece of metal that ends, it's solid but that corner is rusty.
Thanks it was a lot of effort lol and all for naught if I find a place by my folks to blast but ya live and ya learn and I'd rather not fight rust again.
On to my next question, is there a preferred paint for do-it-yourself?
Old Oct 21, 2016 | 04:55 PM
fordguy2100
Thanks I'll look into it
fordguy2100
I HATE RUST!
Never thought of this option, if I can't find a place to blast I'll look into this
Old Oct 21, 2016 | 05:15 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I blasted mine at home with a "cheapie" 100 lb sandblaster from Harbor freight.
Old Oct 21, 2016 | 05:30 PM
fordguy2100
Something like this? That's gunna have to take some convincing on the wife but might come in handy for future projects. Then figure out where to spray the thing down.
If a shop can do it for $35 I'll hop on that for now and keep the blaster on the back burner for the future
Old Oct 21, 2016 | 05:53 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Actually, that one is the current model. The one I have they don't offer any more. I like mine because it doesn't require a funnel to fill the tank with sand. The top end is inverted, making it it's own funnel.
Here's the one I used.
Old Oct 21, 2016 | 08:26 PM
Blue and White's Avatar
Blue and White
It looks like it is pretty well cleaned up. To paint "as is" I would suggest red Rustoleum primer. It is available in spray bomb or can for a sprayer. If you use a sprayer, reduce it just enough with paint thinner so it sprays OK. Then the enamel topcoat of your choice.
The red Rustoleum sticks well to both clean and prepped rusty steel. You have both thus the suggestion.
Old Oct 23, 2016 | 09:50 PM
grinnergetter's Avatar
grinnergetter
Just bring the thing up here and I'll fix you up. Your wearing the hood though.
Make it a warm day and we can shoot it with epoxy primer.
Old Oct 23, 2016 | 11:57 PM
gstirewalt's Avatar
gstirewalt
I used stuff called rust bullet on my frame and support
