Glow plug relay mod help
Old Oct 21, 2016 | 07:58 AM
Jaime74656's Avatar
Jaime74656
ok, I am looking for a good post or write up detailing the wires to use and perhaps a way to route them? I have the LED that I want to use but need to just sort out which terminal to hook the LED to and what size wire to be using, also perhaps what size fuse to use?
truck is a federal E99 (non Cali truck)
Old Oct 21, 2016 | 08:30 AM
Walleye Hunter's Avatar
Walleye Hunter
If I was doing it (and I plan to) I would take it off the large wire on the out side of the GPR, that way you'll know when they're on and if the GPR fails you'll know that too. LED's use very little electricity and the light should have power consumption listed. I'm thinking 14 Ga wire and a small fuse should suffice.
Old Oct 21, 2016 | 08:31 AM
Rikster-7700's Avatar
Rikster-7700
You will hook it to the load (glow plug side) of the relay. This will be one of the bigger posts with no voltage on it when the truck is off. As for wire, #14 or even #16 would be more than sufficient for the current draw you should see. As for the fuse, assuming it is just a "regular" LED then a 3 or 5 amp fuse will be fine, this is still under the current rating of the two wire sizes listed above.
Edit: Walleye beat me to it!
Old Oct 21, 2016 | 10:24 AM
binuya's Avatar
binuya
Oh, c'mon now Jaime! All of the popular mods like these are up at the top of the forum. They're not that difficult to find! https://www.ford-trucks.com/forums/7...wmriceman.html
Old Oct 21, 2016 | 06:22 PM
timmyboy76's Avatar
timmyboy76
Use trailer wire, and hook one up to the starter relay as well
Old Oct 23, 2016 | 01:51 PM
Jaime74656's Avatar
Jaime74656
you mean a separate light? Might be worth it
Old Oct 23, 2016 | 01:55 PM
Jaime74656's Avatar
Jaime74656
Removed….10 char
Old Oct 23, 2016 | 02:59 PM
Walleye Hunter
It's your truck and your final say, but I personally like the one mounted on my bumper, it's low enough to put light infront of me, and not blind other drivers at night, but still able to get the light out far enough to allow for better reaction times if evasive action is required
I'm thinking that this one got posted on the wrong thread for some reason...
Old Nov 2, 2016 | 04:51 PM
Jaime74656's Avatar
Jaime74656
my bad lol
Old Nov 2, 2016 | 05:54 PM
ExPACamper's Avatar
ExPACamper
You have LED with inbuilt resistor, ready for 12v automotive, right?
Old Nov 2, 2016 | 07:44 PM
Jaime74656's Avatar
Jaime74656
not sure about the resister part but it is an automotive LED I got from Autozone, I also put a 5A (I think?) fuse, I think it may really be a 1A fuse
mneves2000
Nov 3, 2016 07:00 PM
tjc transport
Jan 13, 2014 09:54 AM
bearhugger
Oct 8, 2013 02:23 PM
Eallend7
Dec 23, 2012 09:28 PM
Liquid10Rider
15
Jul 8, 2010 08:32 AM
