Glow plugs
Old Oct 8, 2013 | 12:42 PM
bearhugger's Avatar
bearhugger
Glow plugs
Here is the problem,when it goes into the glow plug mode,the relay does not close and the. Small wire that goes to ground through the PCM has about 12v,is there a fuse in that wire,I wouldn't think so.i replaced the relay and it is like the old one was. Thanks for any help. JIM
Old Oct 8, 2013 | 01:32 PM
madpogue's Avatar
madpogue
No, that wire isn't fused. Don't look for voltage on that wire. Disconnect it from the relay and check for resistance. It should read open/infinite resistance when the key is off, and zero ohms / continuity when you turn the key to RUN.
Old Oct 8, 2013 | 02:23 PM
bearhugger's Avatar
bearhugger
Thanks,madpogue,I never would have thought to check it that way,I had a broken wire at the terminal,anyway I got a new relay out of it. Thanks again. JIM
Oldschoolfordlover86
Jun 29, 2014 03:40 PM
bmanis
32
Feb 19, 2012 11:18 AM
powerstroker100
May 28, 2010 12:37 PM
beaver steve
Sep 19, 2009 12:36 PM
Phillyrube
Mar 30, 2009 02:57 PM
