2000 7.3 engine tap
Old Oct 21, 2016 | 05:57 AM
biggdirty7.3's Avatar
biggdirty7.3
2000 7.3 engine tap
My engine makes a slow tap sound
Old Oct 21, 2016 | 06:41 AM
Rikster-7700's Avatar
Rikster-7700
A slow tap from where? And what are we calling slow? Some audio / video would be perfect!
Old Oct 21, 2016 | 11:17 AM
retiredsparky's Avatar
retiredsparky
Buy an auto stethoscope - less than $20 and see if you can isolate the area. Most likely in the valve train (damaged rocker arm, damaged lifter, injector not bolted down tightly), but could be piston related (broken piston skirt, broken rings, piston pin). If the tap is a little heavier sounding could be connecting rod bearing at the crank.
2006powerstroke90
Dec 16, 2011 03:05 PM
CWOODNHD92
23
Mar 15, 2010 11:23 PM
forrdman_67
May 2, 2007 10:20 PM
Lobuks
Apr 13, 2004 10:50 AM
