Compression test kit harbor freight
Old Oct 20, 2016 | 07:38 AM
3000gtman's Avatar
3000gtman
I've seen the us general kits didn't fit out trucks. But according to harbor freight there is a Pittsburg kit for about 30. Says fits ford etc etc. I'm not sure if it's the same kit as before or if it's changed since then. Any ideas? I really don't want to spend 100+ on a kit right this second
Old Oct 20, 2016 | 07:41 AM
3000gtman's Avatar
3000gtman
http://m.harborfreight.com/diesel-engine-compression-tester-20-pc-62594.html
Old Oct 20, 2016 | 08:33 AM
Chevy_Eater's Avatar
Chevy_Eater
Check the FAQ, all the poop is in there.
Harbor freight has 2 kits. The inexpensive one does not work on the 6.9/7.3 although it claims to.
The more expensive kit works fine.
Old Oct 20, 2016 | 08:54 AM
3000gtman's Avatar
3000gtman
There is a big price difference haha one kit is 30. The others over 100. I'm assuming the 30 is the one that doesn't work because of the glow plug adapter. I really didn't want to spend the money to use it once. I just got the truck and want peace of mind the compression is ok. There's no blow by or loss of power but still a peace of mind to know the numbers
Old Oct 20, 2016 | 11:44 AM
Leroy Unlisted's Avatar
Leroy Unlisted
if i recall .. we looked into this before ..
the low cost solution was buying a 10 dollar adapter piece 'tip' and then use the gauge and hoses off the 30$ hf kit ..
Old Oct 20, 2016 | 11:45 AM
Leroy Unlisted
but i'm not 100 percent sure on that ..
Old Oct 20, 2016 | 03:24 PM
Charmalu's Avatar
Charmalu
Here is the link to post#2 the $30 one.
Diesel Engine Compression Tester 20 Pc
And the super duper Diesel one....only $159.99 Remember...it`s only money.
Diesel Compression Tester Set
I bought the cheaper one several years ago.....but they only had the one at the time.
Was going to use it on my Mercedes diesels, and still thinking about using it.
With the MB`s, just remove the Hard lines and do ea Injector at a time,
or remove the GP`s and use the "L" fitting.
I stand staring at this 6.9 and the Octopus of hard lines. Looks like a total
PITA to work on.
Going through the Injector hole or GP hole the lines are in the way.
I have read to just tweek the line to one side and remove the Injector.
Removing the lines looks to be out of the question, the way the IP is made.
Iam not comfortable with slightly bending/tweeking the hard lines.
There must be some super gold plated Ford special tool for R&Ring the
lines off the IP.
Charlie
Old Oct 20, 2016 | 10:16 PM
hairyboxnoogle's Avatar
hairyboxnoogle
I have the cheap one. Injector adapter, no way. A little shortening on the glow plug adapter and it works fine.
Old Oct 20, 2016 | 10:34 PM
The_Josh_Bear's Avatar
The_Josh_Bear
There is an adapter for the cheaper kit to work with our engines, O'Reillys has one. I even used to have the part number...special order of course.
Googling...
Part # MVA5603 less than $9.
Old Oct 21, 2016 | 02:52 AM
3000gtman's Avatar
3000gtman
Hmmmm I'll just pick it up and order the adapter. Thanks guys
Old Oct 21, 2016 | 10:44 PM
Macrobb's Avatar
Macrobb
The HF cheap kit has a glow plug adapter which is "supposed" to work according to the manual... but the thread tolerances are wrong, and it won't go in more than one or two threads.
You might be able to find a die and just re-thread it; IIRC it's 10MMx1.0, which isn't too common, but not impossible to get either.
Old Oct 22, 2016 | 01:07 PM
mattnj's Avatar
mattnj
Even cheaper, $4.59 here Glow Plug Adapter - M10 x 1.0 (Ford/Mazda): Network Tool Warehouse if you don't have O'Reilys within reasonable distance as shipping is not available, at least to my zip.
Old Oct 23, 2016 | 09:55 PM
hairyboxnoogle
The threads are right, the adapter just bottoms out in the pre-cup before the threads catch. Like i said above, i just shortened mine, and it works-- in theory anyway, got rained out and had to use the pickup the next day.
Old Oct 25, 2016 | 08:26 PM
The_Josh_Bear
Well thats good to know! Thanks for the tip, I already have the cheap kit...
fscarrow
Aug 7, 2014 10:11 AM
TheTowingCowboy
Apr 3, 2011 08:54 PM
Tim Shultz
17
Jan 25, 2008 02:16 PM
Onebadpolaris
Modular V10 (6.8l)
Jan 6, 2008 03:36 AM
