They will test and try to charge. You need to have the charging system tested also. My alternator went out and I had one bad battery. I got to find why only one died. A bad battery will kill an alternator and vice versa.
Mine weakened from leaving the lights on overnight last spring. THe charging system would test fine, but after depleting batteries they just aren't as strong and my truck struggles to turn over now. A weak battery is not good for the starter.
Just wondering if their warranty is going to matter in my situation. Also if they are going to deny a warranty if I tell them what happened with the lights being left on one night last year.
Dont tell them. They dont need to know. They changed the warranty policy it now to the day not the month. I just found that out when I tried to warranty my bad one
X2, it's not relative to the warranty and too much info confuses a lot of people and thereby the issue. Don't volunteer unnecessary information.
Running an automotive start type battery down doesn't do them any favors but an otherwise serviceable battery should recover with re-charging. You'll need a charger with serious juice.
What day of the month did you buy it. In my case the battery had a 11/16 sticker. I was there I think the 29 th. When the guy at the service center tried to warranty it. The computer kept rejecting it. The message was tnis item was bought 11/06/16 and not returnable. The guy was shocked also. It is a recent change he did not know about it.
Ted
The OP is concerned about walmart warranting a weak battery. If 8t weak and they try to charge it andc takes charge they may not warranty it. So to ensure they do it needs to be so low it will not take a charge.
For everyday I agree with you
Ah, I see. I think mine are 5 year and at least 3 year warranty.
So.. my batteries are showing weak. Would it not make more sense to just keep running them down till they are literally showing bad, to avoid Walmart from telling me to keep using them? I worry about having to replace a very expensive starter as a result of using a weak battery.
Ted
we posted at the same time lol. on the same page here I think. what's the best way to run down just leave the lights on again?
That what I said earlier. You have to play the game by their rules. If that battery will take a charge they may not warranty it unless it has a bad cell
Ted The OP is concerned about walmart warranting a weak battery. If 8t weak and they try to charge it andc takes charge they may not warranty it.
Why would they want to warranty a battery that just needs charging? LOL!
That's my point. Batteries take a LONG time to charge to 100% and then they really need to cook for a while after that. Chronic undercharging is a big problem. I don't blame them for this. Now you know why a decent batteries cost $150 instead of $75, everybody wants free lifetime battery replacement, because people insist on torturing them on a daily basis, and then bitch that the batteries aren't any good. I'm surprised they last as long as they do. All the major brands make an outstanding product.
As madpogue said, there are only a few battery manufacturers out there.
No, there's actually a metric crapton of battery manufacturers out there. Three companies in the US make the majority - Deka (East Penn), Johnson Controls, and Exide.
