C6 .... 4 speed swap.
Old Oct 19, 2016 | 09:22 AM
kupiec20's Avatar
kupiec20
So i have a 1977 f250 4x4
my C6 is beat.
For some time ive been thinking about throwing in a 4 speed manuel.
i came across a entire setup for the swap.
My question is that it was bolted to a 302.
My truck now has a 351M.
Will this setup work?
ty
Old Oct 19, 2016 | 09:31 AM
okiewelder's Avatar
okiewelder
Swap
Bell housing is different for sure. Flywheel different clutch probably as well. Good luck on your swap
Old Oct 19, 2016 | 10:19 AM
tbear853's Avatar
tbear853
If my '77's C-6 ever craps out ..... I'd look at rebuilding it before I'd even think of a manual .... it is a pretty simple / rugged transmission!
Old Oct 19, 2016 | 10:25 AM
Filthy Beast's Avatar
Filthy Beast
You'll need a different setup as stated above. The 302 has a 10.5" clutch/pressure plate. The 351M has an 11" clutch/pressure plate, the flywheel has 164 teeth, need a 351M/400 bell or one from a 385 series engine.
Clutch fork should be the same as well as the "Z" bar. Find a way to attach the clutch fork return spring....not sure about the driveshaft length or the U joint size for the pinion yoke.
Then there's the hole cutting deal for the trans hump/shifter and pedals.
But you have all that, yes?
Old Oct 19, 2016 | 10:43 AM
kwe45919's Avatar
kwe45919
Truth is it's easier to rebuild the C6.
May even be cheaper in the long run since you have no idea how that 4 speed was used or beaten on as POs usually lie a bit about how they treat stuff, could be more of a hassle down the road...especially if you end up having to rebuild it.
Don't forget about having to add a clutch pedal and linkage....
Old Oct 21, 2016 | 07:39 PM
Motorhead351's Avatar
Motorhead351
It'll cost a hell of a lot more to get a manual transmission settled in place of the C6…......
worth every penny if you ask me.
Old Oct 21, 2016 | 08:18 PM
tabascom16's Avatar
tabascom16
You would just need to find a bell housing for the 351M, and a clutch linkage system. The pedal bracket will have the holes for the clutch pedal already. Tunnel cover with the correct openings. I did the swap once and i cant remember if the driveshaft lengths had to be changed. If i remember correctly i had to move the transfer case support to different holes in the frame which would indicate that one driveshaft would need lengthened and one cut down.
If you don't mind the automatic just buy a rebuilt kit and do it yourself. They really are simple on the inside. Just Carefully remove everything and lay it out in the order you took the stuff out and then just go in the reverse order when re-installing with new clutch packs and bands.
I swapped a 2wd one to a 4wd output shaft one time and had to take it all a part. No special tools were needed and not nearly as complicated inside as you may think. I am sure there are probably some detailed walkthroughs with pictures on the internet or videos on youtube.
bcso290
Jun 5, 2017 01:05 PM
94150
16
Jul 25, 2015 10:09 PM
Bulldog f150
29
Feb 7, 2014 09:44 AM
bigcountry1739
Oct 16, 2013 05:33 PM
75crew
Mar 17, 2002 12:54 AM
