No High Beams
Old Oct 18, 2016 | 12:16 AM
Afuelkid777's Avatar
Afuelkid777
No High Beams
hey guys I have a 2011 ford ranger XL and I get no high beams. My low beams work fine but when I try to either activate the high beams or pull for the flash to pass they do not illuminate and the indicator on the dash doesn't come up either. I have replaced the fuse with a fresh one, even though it didn't need to be replaced, and also replaced the headlights as well cause one was burnt out. I can't figure out what the deal is so if y'all could help that would be great! Thanks!
Old Oct 18, 2016 | 07:37 AM
exranger06's Avatar
exranger06
I would turn the ignition on and turn the high beams on. Pull the fuse and check for voltage at the fuse. If you have voltage, then you have a wiring problem somewhere between the fuse and the headlights. If you don't have voltage, you have either a wiring problem somewhere upstream of the fuse, or a bad multifunction switch.
jolycu
Dec 31, 2007 10:00 PM
ars_lurker
Electrical Systems/Wiring
Jun 30, 2007 06:43 PM
87lx50
Jan 24, 2005 08:40 PM
rebel_gtc
Aug 4, 2004 02:59 AM
