68 f100 engine issues.
Old Oct 17, 2016 | 04:19 PM
Hwklein88's Avatar
Hwklein88
hi,
recenty ive been noticing something odd with my truck. Blue smoke seems to be coming out of my exhaust at idle and when I punch it while driving. Oil pressure is fine when in park and at first while in gear but will drop down to around 25-35psi over time. Just had it backfire as I was driving, this was the first time that this has happened. I've been looking online and sounds like it could be numerous things. What would be the first thing I should look into?
Old Oct 17, 2016 | 05:28 PM
51M1's Avatar
51M1
Compression check.... first thing. have you been using oil? could be worn valve guides????
Old Oct 17, 2016 | 05:35 PM
Hwklein88's Avatar
Hwklein88
no it hasn't been using oil. I just gave it an oil change a few days ago. I ran seafoam spray through the carb and started noticing these issues shortly after using it.
Old Oct 17, 2016 | 05:44 PM
JEFFFAFA's Avatar
JEFFFAFA
What oil did you refill it with? Synthetic?
Old Oct 17, 2016 | 06:11 PM
Hwklein88's Avatar
Hwklein88
Castrol 10w-30
Old Oct 17, 2016 | 06:23 PM
CougarJohn's Avatar
CougarJohn
I would suggest that you buy a gallon of Marvel Mystery Oil and follow directions for a few tankfuls of gasoline as an additive. You may have a sticky valve problem. If it doesn't work, go on to more expensive measures.
Old Oct 17, 2016 | 06:25 PM
Hwklein88's Avatar
Hwklein88
added this yesterday, hoping that it'll help
Old Oct 17, 2016 | 06:35 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by Hwklein88
Castrol 10w-30
In that case I would put some of your MMo or ATF down the carb like you did the Seafoam the other day. 2X John on the sticky valves. As the air/fuel, and this case Seafoam, goes past an open intake valve it hits the exposed part of the intake valve's stem. The Seafoam washed the little bit of oil off the stem that it had. The MMO or ATF might also help the rings if they are sticking also. Which might be where your blue smoke is coming from.
Old Oct 17, 2016 | 06:44 PM
GLR's Avatar
GLR
In addition, bad valve seals...
Macs1964F100
Aug 31, 2014 09:31 PM
myfirstfordtruck
Apr 17, 2013 09:08 PM
Nick Greer
Oct 9, 2012 10:01 PM
Old Rust Bucket
Sep 20, 2006 09:19 PM
kmgplus3
Oct 10, 2002 07:30 AM
