Minor Electrical Gremlin?
Old Oct 17, 2016 | 02:57 PM
LARIAT 85's Avatar
LARIAT 85
When I turn on my vents (from the HVAC panel), my tachometer jumps a second. When I turn them off again, same thing happens. Otherwise, it works fine. I never noticed this happening before; is this normal?
Also, my speedometer cable is "shaky" until about 30 MPH.
My cab was removed for painting a few months ago, so something could be loose. Any ideas?
Old Oct 17, 2016 | 03:05 PM
1986F150six's Avatar
1986F150six
Moat likely, the speedometer cable needs lubrication. I cannot think why the tachometer would jump, since the vents are vacuum controlled. Does the engine momentarily change sound or speed when you do this or is it just the tachometer?
Old Oct 17, 2016 | 03:25 PM
LARIAT 85's Avatar
LARIAT 85
How does one lube the speedometer?
When I move the lever over to turn on or off the vents, the tachometer jumps for a second but the engine doesn't change at all.
Old Oct 17, 2016 | 03:52 PM
Gary Lewis's Avatar
Gary Lewis
The tach issue may be a poor ground in the cab. Try the cigar lighter and see if it does it. The HVAC fan and the lighter are the two highest current draw items in the cab, and if their ground isn't good the current will go back another way, like via the tach's ground.
Old Oct 17, 2016 | 04:14 PM
LARIAT 85's Avatar
LARIAT 85
I was thinking it might be something like that. I never use the cigar lighter, so I would never notice.
Do you know where the grounds are in the cab?
Old Oct 17, 2016 | 04:23 PM
Gary Lewis's Avatar
Gary Lewis
Just so happens there's another thread active about exactly that: Factory Ground Locations
Old Oct 17, 2016 | 06:16 PM
kr98664's Avatar
kr98664
Excellent suggestion.
Does your truck have the AC positions on the selector panel? When you select VENT, are you switching directly from the OFF position? What about when you move the lever to VENT from the other direction (HEAT or DEF)? The reason I'm asking is to see if you are also turning on the fan in the process.
If the fan ground (G701) is suspect, you can easily rig up a test jumper to a good ground via the case of the cigar lighter. Both components are grounded through G701, so if it has worked loose, you can test it by grounding the cigar lighter case.
Gary provided a link in post #6 with more details about G701.
Old Oct 17, 2016 | 07:36 PM
ctubutis's Avatar
ctubutis
David was suggesting lubricating the speedometer cable, not the speedometer itself.
Ford had special lube for that, I think I've used white lithium grease or maybe some sort of graphite thing, don't remember.
Old Oct 17, 2016 | 08:06 PM
LARIAT 85's Avatar
LARIAT 85
Yes.
Yes.
No. The tachometer does not "jump" if I do this. I suppose this means it is the fan ground, right?
Thanks to you and Gary's garagemahal! By looking at Gary's diagram, it appears that the ground wire is bolted behind the instrument panel near right hand side of the radio. Is that right?
Of course! Where do gain access to the speedometer cable in order to lube it?
Old Oct 17, 2016 | 09:22 PM
rowdyredneck's Avatar
rowdyredneck
Yep, white lithium grease works well. Don't use regular wheel bearing or gun grease...its too thick and sticky in cold weather. To lube the cable you'll need to remove the instrument cluster. Once the cable housing is disconnected from the cluster, grab the cable end inside the housing and pull it out. Give it a good coating of grease and slide it back into the housing.
Old Oct 17, 2016 | 09:28 PM
Gary Lewis's Avatar
Gary Lewis
There is also a graphite-based lube that the parts stores used to carry for speedo cables. That is what I've always used. And, Dad taught me to only lube the bottom half of the cable. Otherwise you might get too much lube and it can get into the speedo itself. But, as you slide the cable back in the lube on the bottom half lubes the top of the housing so everything gets lubed.
Old Oct 17, 2016 | 09:48 PM
ctubutis's Avatar
ctubutis
The parts of the cable that can really make use of lubrication are where the holder tube bends corners, as that's where most of the friction occurs.
Old Oct 17, 2016 | 09:58 PM
LARIAT 85's Avatar
LARIAT 85
That sounds good. How do you get to to bottom half of the speedometer cable? Where is it connected to?
Old Oct 17, 2016 | 10:08 PM
Gary Lewis's Avatar
Gary Lewis
Actually, you raise a good question. Normally the cable comes out in 1 piece all the way down to the tranny/t-case and you only lube half of it. But, if you have speed control then you have a 2-part cable. What you'll pull out from the back of the speedo only goes to the transducer, which is close to the firewall in the engine compartment. So, you have to get to the other cable by taking it off at the transducer. (Hmmmm, can the lower cable be taken out from the transmission/t-case end?)
Now, it is remotely possible that Ford did us a favor by allowing both the upper and lower cables to come out at the transducer. So, I would pull them off there loooooong before I pulled the speedo out, and see if the inner cables will come out from there as it would be a lot easier.
Old Jan 26, 2017 | 11:44 AM
JEFFFAFA's Avatar
JEFFFAFA
I just ran across Ford's PTFE lubricant for driveshaft slip yoke splines is also recommended by them to lube speedo cables. It's still available from your local Ford Dealer.
Ford Motorcraft part number XG8A is a 1 lb. container.
Ford Motorcraft part number XG8 is a 3 oz. tube.
One79one71
Jun 5, 2017 11:28 PM
jvmcc
Sep 24, 2016 05:48 PM
Maltman
May 21, 2014 11:32 AM
73f100shorty
May 31, 2007 09:19 AM
texascracker
1978 - 1996 Big Bronco
Apr 8, 2006 11:19 AM
