1978 - 1996 Big Bronco
Cable knock
Old Apr 6, 2006 | 10:44 PM
texascracker's Avatar
texascracker
Cable knock
Excuse my ignorance on the part name, but the speedometer/tach cable is causing a intermittent tapping noise behind the dash. I traced it under the vehicle and felt it vibrating. Is there a quick fix or is it part replacement time. Is it difficult to replace? Thanks for any help.
Old Apr 6, 2006 | 10:53 PM
texascracker
sorry, its a '94 351
Old Apr 7, 2006 | 09:35 AM
Kemicalburns's Avatar
Kemicalburns
sounds like its either not fully seated into the back of speedo or the gear in the transmission is going out. does it drive funny, shift weird?
Old Apr 7, 2006 | 03:53 PM
greystreak92's Avatar
greystreak92
On a 94? Speedo on a 94 has no cable; its completely electronic... it uses information from the VSS and the PSOM module swings the needle accordingly and the tach uses SPOUT signal to determine engine RPM's. The only cables running under the truck are the shift select cable and the parking brake cable.
Old Apr 7, 2006 | 06:35 PM
texascracker
must be the shift select cable. Only problem is a hard shift into second, besides that its just the tapping sound behind the dash. I'm positive its not the brake cable
Old Apr 8, 2006 | 11:19 AM
greystreak92
It could be the PSOM itself. While the signal is electronic the needle is still mechanical.
