overdrive swap
Old Oct 16, 2016 | 11:33 AM
tex4431's Avatar
tex4431
overdrive swap
I have 1967 F100 4x2 with a 300 I-6 & NP435 transmission. I want to put an overdrive transmission in it. What manual overdrive trans will fit in its place with little to no modification?
Last edited by tex4431; Oct 16, 2016 at 12:41 PM. Reason: forgot to put the engine size
Old Oct 16, 2016 | 11:37 AM
ultraranger's Avatar
ultraranger
You left out the part about what engine are we talking about here?
Old Oct 16, 2016 | 12:43 PM
RichS2659's Avatar
RichS2659
Also 2wd/4wd? A OD will not be cheap. Do you use your 67 as a truck or more like a car? Want a low first geared trans or a car trans like a TKO with a high first gear? For an FE engine, there are several options like a NV-4500, A Bendtsen's adapter to mate a SBF trans to an FE, and a Gear Vendors OD. If a 240/300, then these use a Small Block Ford bell housing which you can use any SBF trans like the M-5OD and the ZF-5.
Old Oct 16, 2016 | 03:43 PM
351Cleveland C4's Avatar
351Cleveland C4
I would look for an M5OD-R2 out of a late 80s early 90s bronco/ or F150.
Old Oct 16, 2016 | 05:03 PM
HIO Silver's Avatar
HIO Silver
A T5z...........
Old Oct 16, 2016 | 07:46 PM
Uni Moe's Avatar
Uni Moe
M5R2 5-Speed Transmission Swap Into 67-72 F100 - FORDification.com
Old Oct 16, 2016 | 10:08 PM
Tomahawk's Avatar
Tomahawk
If you go with the M5R2 look for one that is a '91 or older. '92 and newer are not drilled for the cable driven speedometer our trucks use.
Old Oct 17, 2016 | 11:08 AM
Guhfluh's Avatar
Guhfluh
Tremec T-170/"TOD"/RTS is a direct replacement 4 speed OD trans. Mid 80's models. Move the shifter hole back about an inch. Uses a C4 type slip yoke. 2-3 gear spacing is very long, but liveable with enough torque.
Capitlj
17
Dec 12, 2011 06:27 PM
sgtrwg
Flathead V8 & Flathead 6
May 18, 2008 12:40 AM
COSTANGBRA
Jan 28, 2003 12:15 PM
elsmith
Mar 31, 2001 01:07 PM
