Sponsored by: Real Truck
Cold Start Problems 5.4
Old Aug 22, 2003 | 08:21 PM
collier87's Avatar
collier87
After my '03 5.4 SD 4x4 CC Auto sits for a day or more, it has a very low and rough idle condition for about 30 seconds. In this time frame it won't take gas and has NO Power. After the initial 30 seconds of trouble there are no more problems until it sits again. The truck has done this since new and the dealer says the computer has no trouble codes stored in it. My 96 5.0 had this problem and turned out the IAC Valve was shot. Any ideas or do I have to let the dealer keep it for 3 or 4 days to see if they can replicate the problem and then diagnose it in 30 seconds. The truck has 4500 miles on it now. Thanks!
Old Aug 22, 2003 | 08:55 PM
Big's Avatar
Big
Look at this link from the FAQs:
https://www.ford-trucks.com/dcforum/...D117/3953.html
That sounds like the problem I had once or twice. It went away with no fix needed and did not need to sit for it to happen. As I remember, this link should help you out.
Big
Old Aug 22, 2003 | 10:00 PM
99f350sd's Avatar
99f350sd
Sounds like a fuel pump problem! The dealer can put a gauge on it and see if it has the correct psi at startup.
99f350sd's Avatar
99f350sd
Old Aug 22, 2003 | 10:29 PM
FortyFords's Avatar
FortyFords
yes ,can be fuel pump ,the check valve within the fuel pump doesn't hold pressure in the line after sitting.
Have also seen it be IAC valve .
Rich
Find another dealer ,its not supposed to do that .
or go back and tell them what you want checked,that always gets their attn.
Old Aug 23, 2003 | 09:26 AM
collier87's Avatar
collier87
Thanks for the info. I'll make an appointment this week and we'll see what they say! You guys are great!
Old Aug 24, 2003 | 07:41 PM
Engager's Avatar
Engager
I had the same problem. There is a TSB out on this condition and it calls for changing the faulty oxygen sensors. Changed mine and haven't had a problem since. Good luck.
Old Aug 24, 2003 | 07:47 PM
99f350sd's Avatar
99f350sd
O2 sensors shouldn't come into play until warmup. And definetly not on cold start. Unless i'm missing something...
Old Aug 25, 2003 | 07:42 PM
Engager's Avatar
Engager
I'm no mechanic, but my problem was rough idle only at cold start up. They changed the oxy sensors and it has been fine since!
2003 F-350 5.4L 4.10/gears
Old Sep 3, 2003 | 04:50 PM
collier87's Avatar
collier87
Couldn't give my truck up this week for 3 days. Oddly enough, the problem hasn't happened since my last trip to the dealership. Maybe it cured itself(LOL). I guess I'll wait and see! Thanks again!
Old Nov 3, 2003 | 06:33 PM
collier87's Avatar
collier87
Finally able to get truck back to dealership! I advised them of the TSB( Thanks Engager!), they replaced the O2 Sensors. The problem is now gone! I wouldn't have suspected them as the problem. Amazing that the customer has to tell the dealership what to fix! Thanks for all the support!! See 'yall later!
Old Nov 3, 2003 | 07:08 PM
Engager's Avatar
Engager
It really is amazing what we learn over here. I don't post often, but I read every day. This forum is great!! Glad you got your truck fixed Collier.
Old Nov 3, 2003 | 07:24 PM
Kraut's Avatar
Kraut
Re: Cold Start Problems 5.4
Big Time Ditto.....
My '03 5.4 did this too... threw no codes.
Went to my dealer, they checked the IAC, which they said came back normal...
ended up replacing O2 sensor, and NO PROBLEM SINCE.....
Old Nov 4, 2003 | 08:01 AM
FortyFords's Avatar
FortyFords
Glad you got it fixed !
The 02 sensors failing would have eventually posted a DTC and a MIL light after so many drive cycles .
Rich
GregPeck
2004 - 2008 F150
Jan 17, 2016 12:14 PM
kpchambers
2009 - 2014 F150
Nov 12, 2015 03:44 AM
mustang88
1997 - 2003 F150
Jan 19, 2015 05:56 PM
Daviddc114
31
Oct 15, 2007 07:57 PM
