DELAMINATION
Old May 19, 2017 | 10:53 AM
  #61
RV_Tech's Avatar
RV_Tech
I think this repair looks fine and makes perfect sense. I would never have put thousands of dollars into any older RV, unless it is something truly unique or collectible. So nice job!
Steve
Old May 19, 2017 | 11:01 AM
  #62
HRTKD's Avatar
HRTKD
Is the skin made of fiberglass? I've heard of gel coat but have no clue what that is.
Old May 19, 2017 | 01:21 PM
  #63
scraprat's Avatar
scraprat
Top Answer: 5
Wikipedia
Gelcoat or "'Gel Coat'" is a material used to provide a high-quality finish on the visible surface of a fibre-reinforced composite.
Old May 19, 2017 | 01:41 PM
  #64
RV_Tech's Avatar
RV_Tech
Originally Posted by scraprat
Wikipedia
look up "filon".
steve
Old May 19, 2017 | 01:43 PM
  #65
scraprat's Avatar
scraprat
Top Answer: 5
Thanks Steve I couldn't remember what it was called.
Old May 19, 2017 | 02:03 PM
  #66
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Steve
Thanks Steve..sure makes me fell a lot better coming from a "PRO" !
Old May 24, 2017 | 12:52 PM
  #67
Irelands child's Avatar
Irelands child
Just been watching your repair from the sideline, Bud. The repair looks good enough to me.
With that you could screw/glue a piece of aluminum, say 1/8" thick, rattle can painted to match over the patch and make up a matching piece for the other end of the slide opening. Or run it the entire length of the slide.
Regardless, your repair looks and works well and easy on the wallet
Old May 24, 2017 | 01:43 PM
  #68
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
No, I don't think that would only make it worse looking and not contribute to the fix. No way any rattle can color will match the RV.... the Dycor and EternaBond is close enough for me.
Old May 24, 2017 | 01:47 PM
  #69
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
The only thing I'm thinking of now is to purchase a different pinbox. Mine is a standard solid Lippert so I've been looking at getting a MorRyde with the rubber shock mount built into it. I'm thinking it will reduce the shock of start/stop and bounce to lessen the chances of more cracking.
Old May 27, 2017 | 04:59 PM
  #70
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Bought a 2 year old MorRyde and got it all in today. Now to take it out on the road and see how it does and to make sure that the crack don't come back!!! Maybe tomorrow? IF it don't rain.
Old May 28, 2017 | 06:21 AM
  #71
senix's Avatar
senix
I bet it does just fine.
Be sure to re-torque that pin box after your test drive.
Old May 28, 2017 | 09:45 AM
  #72
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Thanks Scott... I would have forgotten!! Prob won't go out with it until tomorrow or Tuesday now. Gonna de-winterize it today and then family obligations.
RV_Tech
All Things Towing
23
Aug 29, 2016 08:31 PM
Greywolf
All Things Towing
59
May 15, 2013 09:13 PM
Greywolf
All Things Towing
Mar 24, 2007 08:09 PM
Greywolf
All Things Towing
Mar 6, 2007 10:06 PM
wdsmithjr
Garage & Workshop
Jan 21, 2004 03:15 PM
